Ended up not using this stem and changed to a chrome stem. It is in like-new condition with light wear on the inside from being mount on the bike.
Asking $60 shipped ($99 New)
Ruff Stem A-Head 1 1/8 Inch
The perfect Ruff connection between fork and handlebar. Built from a solid piece of 6 Series Alloy and coloured in peened-anodized black it has our skully engraved at the front to look out for you. The materials structure is aligned for an maximum strength and undoubtly a benchmark in stiffness with a low weight of 180g.Custom built for Ruff Cycles it holds handlebars with a diameter of 25,4 mm.With a true angle of 0° there is no rise of the handle bars.
The face plate comes with a 4 bolt face plate and supports 1/ 1/8" head tubes.
aluminium body
detachable handlebar clamp handlebar acceptance 25,4 mm
for 1 1/8 inch. a-head shafts / headsets
~ 42 mm offset
aluminium body
~ 42 mm offset
