I've got a rear wheel with a coaster brake, it's a Perry i got for $20. The brake is a little on the scary side, just bad enough to be thrilling but it stops eventually which i think is exactly how rat rod brakes should be. The thing i'm not too sure about is that once you brake and start to crank again there is a least a quarter turn before you actually get tension. Maybe i'm just not used to a classic wheel or does something need to be adjusted?
