I have just begun stripping down a 1952 BF Goodrich Schwinn Hornet. There is a fair bit of corrosion on every bolt and nut, so I sprayed PB Blaster on everything a few days ago and started taking the socket wrench to it earlier today. Everything seems to have freed up nicely except the quill stem bolt. I haven't given up on the idea that it will bust loose with the penetrating solvent and I've re-bathed it in PBB, but I'd like to know some tricks in case I can't break it loose with a socket wrench and elbow grease a few more times.
Another item... The saddle from this bike is the type on which the cover is sandwiched between an upper and lower pan that are bolted together. I will take it apart, clean it up, and re-cover it. Once I get the springs off the assembly, what is the best way to clean and refinish them? I am set up to sandblast with silicon carbide grit (I sandblast glass with it), but I've never sandblasted metal so I'm not sure whether SiC is suitable for this application.
Any advice appreciated.
Cliff
Cliff
