Could this be made into a pedal bike even though it started life as a motor bike frame?
I have the Schwinn OCC StingRay that could be used for the rear wheel and maybe the triple tree.outskirtscustoms said:I've seen one, they came with a small motor that mounted over the rear wheel. I see no reason you can't turn it into a bicycle although finding the right size seat post and bearings may be a challenge.
They also came branded as AMF, Roadmaster, and a few others.
Or maybe go for a Yamaha motobike vibe and .....
dracothered said:I'm wondering if the engine shown here would fit under the bar and link up to the wider StingRay rear wheel?
Yea I don't want a friction drive, so I will go with a chain drive set up.ozzmonaut said:Also the motors were drive wheel type. They are basically a regular bike aside from a motor sitting on top. Mine had standard crank, bearings etc. The wheel is stamped AMF 16" but uses DOT sizing rather than bicycle sizes. Mine had no motor when I got it for $5 from the flea market but still rode fine. I like how the front sticker has legitimate motor vehicle info.
