Single speed to multi speed
Apr 18, 2012
435
163
St. Louis, Mo
1   0   0
I may be getting a typhoon (not sure of the year) I’m gonna move my ebike kit from my Electra townie to the typhoon.
can I add a rear derailleur and use the 7 speed freewheel if I swap the front chainring with one from a varsity?
why do this?
I dunno
I do plan on adding disk brakes to this build, I’m replacing both the wheels
(I’ll hang on to the original, everything will be reversible)
I’m also hoping to put a triple tree or maybe a springer in front with a disk tab.
Has anyone done this and do you have examples so I can steal your ideas?
So a multi speed chain will work on a single speed front sprocket? I guess it’s a width thing and not a chain size thing.
there are four types of main chains.
#1 standard on BMX, beach cruisers. three wheels, Walmart sold bikes. that are single or five speed.
#2 is narrower/ slimmer found on high end road bikes and mountain bikes. yet not a must have to work with derailleurs.
#3 old skip tooth chains only work with skip tooth sprockets.
#4 only really used for micro tiny sprockets. the half link chains.
We're talking bikes here so there's always exceptions to any rule :)
1/8" Wide chain is bmx single speed
3/32 wide chain is multi speed chain
Now many bmx came with 1/8 freewheels but 3/32 front sprockets. Make sure your front sprocket will fit a 3/32 chain, the chain should drop freely and evenly onto the teeth.
3/32 freewheels are out there, usually in higher tooth counts to match with 26" cruiser gearing.
If youre planning on a multi speed. You need a 3/32 chain. Make sure your front sprocket fits.
Newer multi speed drivetrains, 7, 9, 11 rear gear clusters may require specific chains for those derailleurs. Google the chain required for your brand 7 speed and derailleur. I personally use KMC on everything, same color, save the spare links, use a chain tool with no master link and after a few bikes, I get a bonus chain with the left overs.
