Made my 1st custom head badge
Oct 13, 2011
179
26
Waxahachie, TX
I now many of these have been posted before but it's pretty cool to do and thought I would share.
Here are some photos of the acid etched badge.
Heat transferred to tin, should have used aluminum.
Etching in acid mixture:
After some trimming, painting and light sanding.
Finished badge on bike. Made from tin and etched with acid. Probably use a lighter metal like aluminum or copper next time. The etching wasn't as deep as I'd like it to be. Took a little trial and error but once you get it it turns out great. Not sure why I chose tin but it worked ok for now.
Re: Made my 1st head badge too
What solution are you using?
I have used ferric chloride and PnP resist for my brass badges.
I heard caution should be used ( I'm sure you take precautions) with certain chemicals and aluminium as it will out gas hydrogen.... it may have been caustic soda... can't recall.
BTW... nice job. I'm diggin your logo.:cool::cool::cool:
I do headbadges....more diesel punk look than yours, but your piece is OUTSTANDING!! :D Nice work!
Thanks for the compliments guys.
low~N~slo
I am using a 2 parts hydrogen peroxide 1 part muradic acid and soaking for about 20 or so minutes. I may use a tad bit more acid in the next attempt but I really want to try copper or brass. Yours looks awesome.
I designed the artwork in a graphic program then printed it out on a piece of scrap label paper backing. The slick side. I then used my heat press to transfer it to the metal. Worked like a charm.
Like! Between the old looking tombstone graphics and your etch job the thing looks like an antique. Nice job! Gary
