ATOMIC PUNK - New camera time - August 8
226 posts • Page 10 of 16 • 1 ... 7, 8, 9, 10, 11, 12, 13 ... 16
Re: ATOMIC PUNK - Fooling around with a headlight - June 19
Postby bean on Tue Jun 19, 2012 12:32 am
I deleted the pic of my cut finger in my last post........my wife said it looked like I was flipping the bird :oops: :oops: :oops:
I started playing around with headlight mounting today. This one is the favorite so far. I would like to find something smaller, or maybe even a pair of smaller lights, but given the things I still need to do to this bike and the building time I will have, this will probably be the light I'll use (with a different mount).
bean
Re: ATOMIC PUNK - Headlight Mounting - June 19
Postby Circa Cycles on Tue Jun 19, 2012 5:50 am
That light is pretty cool.But the white circles are sliding off your frame :!:
Circa Cycles
Postby bean on Tue Jun 19, 2012 2:02 pm
Circa Cycles wrote:That light is pretty cool.But the white circles are sliding off your frame :!:
Yeah, I was thinking about some holes in the tank area for a while..........changed my mind and painted some on the downtube to look at for a couple of days.........I think they will slide off and stay off :wink:
bean
Postby Critter1 on Tue Jun 19, 2012 2:08 pm
If you could drill the holes out and fill them with the same OD tubing and weld up the seams & blend them all in... That would look sweet.
Like this:
Justin
Critter1
Postby Dr. Tankenstein on Tue Jun 19, 2012 2:31 pm
I think with the visual 'weight' of the front end, adding holes to the frame would make it look 'frail' in comparison, i would forego the holes.
just my .02
BTW, this may be the 'BADDEST' front end I've seen in a long time!
Cheers,
Postby Circa Cycles on Tue Jun 19, 2012 4:01 pm
Never hurts to explore your options.You made a wise choice,imho :wink:
Circa Cycles
Postby bean on Tue Jun 19, 2012 4:08 pm
Critter1 wrote:If you could drill the holes out and fill them with the same OD tubing and weld up the seams & blend them all in... That would look sweet.
Like this:
That was the plan, but after looking at it for a day or two I decided to not do the holes.
Dr. Tankenstein wrote:I think with the visual 'weight' of the front end, adding holes to the frame would make it look 'frail' in comparison, i would forego the holes.
just my .02
Cheers,
Thanks Dr.T. Yep, I agree on the holes for the very reason you posted :D
bean
Re: ATOMIC PUNK - More tail light work - June 21
Postby bean on Thu Jun 21, 2012 4:39 am
I bent a piece of transluscent red acrylic around some pipe to make a cover for the inside of the light. Just have to clean the glue residue off the inside of the mic case and polish it to make it glow. I'm just going to hot glue the red cover in to make it easy remove to change batteries.
bean
Postby Circa Cycles on Thu Jun 21, 2012 6:17 am
Cool :!: Should look nice polished up 8) 8)
Circa Cycles
Postby kingfish254 on Thu Jun 21, 2012 10:23 pm
Nice work on the mic light.
Looking forward to seeing it glow red!
Re: ATOMIC PUNK - Little Punk tag - June 22
Postby bean on Fri Jun 22, 2012 3:06 am
I wanted to do something with the disc brake tabs on the fork leg
So I cut some 2mm aluminium into a strip
Used some of these
To make this
Not sure if rivets will be the final mounting method, and it'll get polished later on.
bean
Re: ATOMIC PUNK - LED Sled - June 24
Postby bean on Sun Jun 24, 2012 3:47 am
I'm going to weld a plate at the top of the seat stays from the post to the brake bridge to add a support for the seat pan, so decided to have a play around with a green flexi LED strip I've had floating around for years. If I decide to use it, it will be under the plate and not visible......the battery holder would be hidden under there as well. I'll keep looking at it over the next couple of days to see if it stays or not. The Flying A may or may not end up there as well ...........just throwin' ideas around :? :? :?
bean
Postby kingfish254 on Sun Jun 24, 2012 8:26 am
Green Lantern
Postby Critter1 on Sun Jun 24, 2012 11:21 am
I'm really liking the flying-A location!
Justin
Critter1
Postby bean on Sun Jun 24, 2012 9:42 pm
Critter1 wrote:I'm really liking the flying-A location!
The more I look at it the more I think it will stay there. I just need some fine weather and a whole day free :shock: , so I can get the frame back to bare metal and clear coat it.
bean
