POST your custom shifters
47 posts • Page 2 of 4 • 1, 2, 3, 4
Re: POST your custom shifters............
Re: POST your custom shiftersnot sure if any pictures on this thread include this.....but a lot of these i've seen include chrome/metal housings just off the shift that allow for a quick and sharp bend. The closest thing ive found online are brake cable noodles. Is that what these are or am i missing the right name?
Re: POST your custom shiftersXC204, that is a nice piece of work!
What are the two 'extra' screws 180deg. apart around the lever pivot? So many bikes, so little time.......
Re: POST your custom shiftersshimano stem clamp mounted on seatpost with one side taken off.. had to rig a smooth cable guide at the bb though, this was for the rear deraileur
Re: POST your custom shiftersNexus 7 Speed shifter on the Phat Chopper:
Re: POST your custom shiftersNexus 7 speed on electrified Phat Stretch:
Re: POST your custom shiftersI have a 3spd Sturmey Archer AWC hub..brand new...what would I need to get to make this work?
http://www.ebay.com/itm/290459076506?ss ... 1438.l2648
Re: POST your custom shiftersTons of cool ideas and inspiration here.
Hoping to add my BO7 shifter later on. BO8 FireWing-Flexy-Fugsley-Beer Run * SALE ITEMS, FRESH FINDS + KINGFISH254 Stuff
Re: POST your custom shiftersfine tuned rear hub and changed shifter:
Can you blow it up for me? I remember trying this out a few years ago but couldnt find a way out since its all plastic and couldnt find a way to properly join a steel lever to it. keep in mind that if its not weldable im a retard so you might wanna explain it slowly also, the mechanism was broke somehwere, ill look at it later today. and thanx Unity Lowrider Car Club
It's quite simple! I've deleted rubber grip from the shifter, cutted off plastic ears that were holding the grip, just left four of them, then putted 31,4mm seatpost clamp so that the gap which holds the bolt was right above these ears. Then inserted the stem that hols the mirror (as seen on a picture) and screwed with 2 M8 nuts. Then used threaded ahead stem for mounting the shifter on a seatpost instead of seatpost clamp. That's it!
Re: POST your custom shiftersHere's a 3 speed bar end twist grip shifter converted to stick shifter:
Who is onlineUsers browsing this forum: TubatronSXT and 7 guests |
