█ Flex★Liner⑦ █ TWINFLEX SPACELINER 4/26 Yoots Higgins Ride
1666 posts • Page 7 of 112 • 1 ... 4, 5, 6, 7, 8, 9, 10 ... 112
Re: FlexLiner MO FATTA TwinFlex Spaceliner 5/17 Actual Work
Postby kingfish254 on Fri May 18, 2012 5:16 am
bighit wrote:Just make sure it's sturdy enough so you don't get wheel flop.
Yeah, and another thing I need to keep in mind is play in the chain. I may need to use a chain tensioner.
Or, instead of using the IGH SA5, Maybe I could lace up a 24" rim to the hub from my 79 Spitfire 5. It has an Atom Drum Brake on it, which would be pretty cool as well.
Postby kingfish254 on Fri May 18, 2012 5:19 am
deezenuts wrote:looks like its time for the kindergarden cop reference. . . "Its not a tumor! :x " haha :lol:
I love that "tooo mahh" line.
Postby kingfish254 on Fri May 18, 2012 5:21 am
tin machine wrote:hey thats a great idea the first fullsuspension bike 1939 , how cool is that you get some vote if you pull thay off my man ,,,yeah baby :!: :!: 8) 8)
Thanks Tin, There are definitely more than a few factors to consider, but I think I can make it happen. Not that you really need suspension when you are riding on 24x3 tires, but there is the "CUZ I CAN" coolness factor.
Postby raggedjim on Fri May 18, 2012 7:33 am
Ahhh, KIng, I bought a bunch of parts to build my version of a twinflex (well a faux twinflex), didn't realize you were headed in this direction. It's a double spring version. If it will step on your toes I'll back off of it, your call...
Rg
raggedjim
Postby kingfish254 on Fri May 18, 2012 7:37 am
raggedjim wrote:Ahhh, KIng, I bought a bunch of parts to build my version of a twinflex (well a faux twinflex), didn't realize you were headed in this direction. It's a double spring version. If it will step on your toes I'll back off of it, your call...
Rg
Don't even consider backing off! Go for it!!! There are multiple home grown real and faux front springers and I never get tired of seeing them. No reason why rear springers should be any different. I look forward to seeing what your take on the idea turns out to be.
Postby Dr. Tankenstein on Fri May 18, 2012 7:41 am
Something to think about.....when the rear suspension flexes, how does the chain react? Since it pivots around a common fulcrum, I would assume the chain wouldn't slack too much, right? Is a tensioner or derailleur needed? How did Huffman do it?
Looking forward to seeing this in person one day!
Cheers,
Postby kingfish254 on Fri May 18, 2012 7:44 am
Dr. Tankenstein wrote:Something to think about.....when the rear suspension flexes, how does the chain react? Since it pivots around a common fulcrum, I would assume the chain wouldn't slack too much, right? Is a tensioner or derailleur needed? How did Huffman do it?
Cheers,
It probably depends on how much travel, but typically you don't see IGH's on rear suspension bikes without a tensioner. I would prefer to have the IGH, but the atom brake Spitfire hub would be cool too. Either way, I could make the twin bar shifter work.
Postby Xcruiser on Fri May 18, 2012 7:49 am
Bout time you showed up!!!!!!!!!!
Postby kingfish254 on Fri May 18, 2012 7:53 am
Xcruiser wrote:Bout time you showed up!!!!!!!!!!
The weekend is almost here too. Gonna have some fun.
Postby raggedjim on Fri May 18, 2012 8:31 am
Don't even consider backing off! Go for it!!! There are multiple home grown real and faux front springers and I never get tired of seeing them. No reason why rear springers should be any different. I look forward to seeing what your take on the idea turns out to be.[/quote]
I knew that would be your reply... Mine will be thrown together from bits a pieces.
Good luck, Rg
raggedjim
Postby kingfish254 on Fri May 18, 2012 8:35 am
raggedjim wrote:I knew that would be your reply... Mine will be thrown together from bits a pieces.
So will mine!! :wink:
Postby whoinphx on Fri May 18, 2012 8:44 am
Aahhh.... It is nice to have you back in the country....
Everything you're describing sounds pretty darn cool....
I can't wait to see what you come up with....
So It Goes ....
whoinphx
Postby kingfish254 on Fri May 18, 2012 8:45 am
Here is my normal full suspension ride (a Dahon Jetstream P8 folding bike) with hydraulic brakes.
I want to see someone make a homemade front suspension like this one.
Postby kingfish254 on Fri May 18, 2012 8:46 am
whoinphx wrote:Aahhh.... It is nice to have you back in the country....
thanks Who!
I can't wait to see either :P
Postby kingfish254 on Fri May 18, 2012 9:09 am
Look at the cool space age bike helmet I plan to use for my Spaceliner.
