Old Fork To Bigger Axle
9 posts • Page 1 of 1
Postby kngtmat on Wed May 09, 2012 5:19 pm
For all kinds of forks.
What are the ways to get old bicycle forks to except the newer bigger axles?
kngtmat
Re: Old Fork To Bigger Axle
Postby thatismytruck on Wed May 09, 2012 5:44 pm
I file the forks a little on both sides.
Skip
thatismytruck
Postby expjawa on Wed May 09, 2012 8:34 pm
thatismytruck wrote:I file the forks a little on both sides.
That.
Some form of filing or grinding to widen the slot. Do it carefully and evenly to make sure that the axle alignment is retained.
Rick the Jawa
(Packrat & Part Hoarder)
Click here for a 3-Star Delusion...
expjawa
Postby CCR on Wed May 09, 2012 8:56 pm
Or file the axle but i prefer filing the forks instead.
jeremy
Postby cman on Wed May 09, 2012 9:52 pm
Axels are easier to replace if something happens.
Postby expjawa on Thu May 10, 2012 7:49 am
Filing the axle creates a stress riser that could lead to a failure. Opening the fork up, not so much. Granted, it will probably not likely be an issue, but I wouldn't do it just on principle. There probably is a reason that the industry moved to a larger standard size. That, and I'd imagine a front axle failure could be, um, eventful...
Rick the Jawa
expjawa
Postby gcrank1 on Thu May 10, 2012 8:38 pm
Not sure at all, but, Ive worked with a lot of different kinds of steel through the years and the new, bigger dia. axles dont seen to be as good a steel as the old ones. My guess (and guess it is) is that the lower quality, but bigger dia. probably about equals the older, small dia. 'better' steel. Im inclined to open up the dropouts if needed.
gcrank1
Postby kngtmat on Fri May 11, 2012 1:58 pm
Ok because part of the reason I wanted to know is that Spaceliner Klunker I have, whoever owned the bike did it when he turned it into a Klunker.
kngtmat
Postby deorman on Sun May 13, 2012 4:58 pm
gcrank1 wrote: Im inclined to open up the dropouts if needed.
Ditto.
Return to HOW TO
