New School "moving to finished"
484 posts • Page 5 of 33 • 1, 2, 3, 4, 5, 6, 7, 8 ... 33
Re: New School "WE Have Fat Bike"
Postby bighit on Fri May 04, 2012 7:24 pm
tin machine wrote:cool suff there :mrgreen: 8) alway around man ....wow
thanks, my goal is New School Muscle Car stealth.
bighit
Postby bighit on Sat May 05, 2012 6:27 am
ok its time to make some room in these stays. i figure i needed a 1/2 inch on each side just be sure nothing would rub.
i bolted in the rear triangle to keep the 135mm spacing. then i got out my car jack and placed it exactly where the widest part of the tire goes.
you need at least 4" of clearance for this tire. i started off at 3" so i was willing to blow it up to pull it off. having a welder waiting in the wings to fix any problems gave me the confidence to Jack The Frame Up!
there you go, New School. Dont say Bighit dosent give back to RRB.
bighit
Postby Jake Sensi on Sat May 05, 2012 7:03 am
MplsCoaster wrote:The Fat Tire War was just escalated. Nice Job!!
YEAH, WHAT HE SAID!! IN THE WORDS OF A WISE MAN(MOE HOWARD) HEY, SPREAD OUT!! :D PEACE
Ride and Rat On
Jake Sensi
Re: New School "Jacked It Up"
Postby bighit on Sat May 05, 2012 8:09 am
I am afraid to go bigger and try the 4.7's because i don't want to over stress it.
I still have to account for the 78mm wide bottom bracket. Most fat bikes take a 100mm bottom bracket to clear the fat tire. I can tell you that the cranks hit the frame now and I have to get new ones, but which ones?
Thats in the next class :wink: that is why it's called new school.
bighit
Postby Dr. Tankenstein on Sat May 05, 2012 10:18 am
You could rob the BB off an OCC StingRay. The rear on those is wider than what I think you're trying to squeeze into your frame, that BB would definitely be wide enough.
I'm lovin' this build so far, keep it up.
Cheers,
Postby chepe13 on Sat May 05, 2012 11:02 am
Vey cool, Those tires are going to look amazing.
bikes...they make me smile
chepe13
Postby pick on Sat May 05, 2012 11:05 am
SWEEEEEEET!!! 8) Love them fat tires!
My Favorite Color is Rust!
pick
Postby bighit on Sat May 05, 2012 5:12 pm
I have the Black floyds for road work and a set of endos for off road. Two very distinct looks.
No need to do anything to the Bottom Bracket. This is "new school" so it will fit right into the frame without any mods. I know its gold chain, but it is very good info and will bring this game to the next level.
bighit
Postby JoKeR63 on Sat May 05, 2012 5:24 pm
Mountain bike cranks usually are well offset. Then just take off the smaller rings.
JoKeR63
Postby motopsyco on Sat May 05, 2012 7:27 pm
The easiest thing to do with those braces you cut is just to cut 'em completely out and replace them. Looks great so far.
http://www.motopsyco.com
motopsyco
Postby bighit on Sun May 06, 2012 5:33 am
i really dont think i need them right now. i will weld some type of gusset in there next. a plate on the bottom for the kick stand and a fender mount on top should help stiffen it up, but these tubes are so big as you can see.
bighit
Re: New School "Cut That $..t Out"
Postby imagearchy on Sun May 06, 2012 11:55 pm
I think you right.. the triangulation of the axle will be fairly strong. "if it ain't broke..."
iMaGeArChY E.· ` ' / ·. F
imagearchy
Re: New School "Stripper!"
Postby bighit on Mon May 07, 2012 7:30 am
Time to strip off this green paint so we can get to work. here we go with the airplane paint stripper from auto zone. this stuff is nasty so get safety gear.
it comes in a gel so you have to paint it on.
i didnt even get the bike finished and i looked up and bam the paint was peeling off.
apply a few coats, scrape it off. i then hit it with a power washer to knock the rest off and wash off the stripper Glitter. :mrgreen:
bighit
Postby yoothgeye on Mon May 07, 2012 7:43 am
I remember the first time I used airplane stripper, it was on a KA24DE aluminum valve cover, I was amazed at how well that stuff worked... and just how a tiny bit could so quickly burn you! haha
Looking good.
Postby bighit on Mon May 07, 2012 9:25 am
You can feel the fumes burns your face, good stuff.
For a New School frame with powder coating it's the only way to strip it. Dangerous, but easy.
bighit
