Sweet Fancy Moses (Some bike work and another sidetrack!!!)
85 posts • Page 2 of 6 • 1, 2, 3, 4, 5, 6
Sweet Fancy Moses
Postby Critter1 on Wed May 02, 2012 5:27 pm
Perfect! Make room for those meats!! I see what your talking about now... :)
Check out this years Build Off bike ---> Old Soul
Justin
Critter1
Re: Sweet Fancy Moses
Postby inshane64 on Wed May 02, 2012 11:19 pm
Time to make room for my tires!!!
To make the tires fit I need to cut off the kickstand.
The rear fender mount also hasta go.
Spreading will be made easy thanks to NAPA's Spring Lift Kit
Here it is in action:
Now to cut the kickstand on one side to allow movement
I used a bar clamp to make sure the movement does not just occur where the tube was weakened from the cut.
After spreading I put a block of wood to keep it where I wanted it while I welded.
Block of wood and metal dolly in place to keep the shape I want the frame to stay in while I pull the dropouts to their proper width.
Again pulling the dropouts together.
Tomorrow I will see how Fancy Moses is gonna look on the ground and hopefully take a spin around the block!!
My Intro, My First Build
RRBO#6 SpringLiner Build, Finished Pics
RRBO#7 Sweet Fancy Moses
inshane64
Sweet Fancy Moses
Postby Critter1 on Wed May 02, 2012 11:41 pm
Nice work man!
Justin
Critter1
Postby KOTA on Thu May 03, 2012 6:02 pm
NICELY DONE!
Postby inshane64 on Thu May 03, 2012 6:03 pm
Wheel-set meets Frame!!!!
Took it out for a cruise today!!!
Back tire is lookin' fine.
Front tire not so much.
Altho the tire is perfectly centered 'tween the forks when riding bumps and turns make metal and rubber meet. You can see the rubber dust in these two pics.
You can't tell but they have ample clearence when parked, but during a ride I can notice rub. The wheels are true. I have no experience with these forks is this normal? Does the design not allow you to keep a wheel-set in place?
I did put some washers on the fork to give me the clearance I thought I needed.
inshane64
Postby inshane64 on Thu May 03, 2012 6:04 pm
KOTA wrote:NICELY DONE!
Thanks Kota! I am still mourning the loss of RU Slammed!! Hahaha
inshane64
Postby KOTA on Thu May 03, 2012 6:12 pm
Might need a wider wheel hub (front). Even with the washers up at the top, you might be squeezing the fork tubes to much at the axle.
Mourning RU Slammed...Me too! :lol:
Postby SCHWINNRAY69 on Thu May 03, 2012 6:24 pm
Bike looks great so far! :wink: Are those the handlebars staying on, if so, they look awesome :mrgreen:
Postby inshane64 on Thu May 03, 2012 10:43 pm
SCHWINNRAY69 wrote:Are those the handlebars staying on
That's the plan for now!
I finished sandblasting the skirts and fender.
A few places on the chain guard side had some pitting, here is some pitting in the skirt:
Pitting on the chain guard.
Time for some primer.
Before primer.
After primer.
Here is the primer I am using.
I will haffta fix this tomorrow before primer.
inshane64
Re: Sweet Fancy Moses (Schwinn Springer Issues)
Postby cman on Fri May 04, 2012 12:55 pm
Looking great. Try adding some washers down at the axle inside the fork.
Postby deven_science on Fri May 04, 2012 1:02 pm
cman wrote:Looking great. Try adding some washers down at the axle inside the fork.
*What I was going to say.
deven_science
Postby Xcruiser on Fri May 04, 2012 1:04 pm
One of the biggest factors with schwinn type springers flexing side to side and rubbing is not having the pivot bolt tight enough.You can actually tighten them quite a bit and they will still function fine.I had this issue before-I left the pivot bolt kinda snug at best and It allowed too much motion side to side.
In your case I agree with the above,you will need to spread a bit,you wont be able to prevent such a tight amount of flex with that big tire.
Good luck and good building bro!
Postby inshane64 on Fri May 04, 2012 5:04 pm
deven_science wrote:What I was going to say.
Xcruiser wrote:One of the biggest factors with schwinn type springers flexing side to side and rubbing is not having the pivot bolt tight enough.You can actually tighten them quite a bit and they will still function fine.I had this issue before-I left the pivot bolt kinda snug at best and It allowed too much motion side to side.
Thanks guys I will defiantly try these fixes, I have no experience with a schwinn style springer so all your help is valued.
I have 2 different options that imma try tonight, I will post some pics and see what you guys think.
inshane64
Postby tin machine on Fri May 04, 2012 5:10 pm
awesome stuff looks great 8)
Postby tanksalot on Fri May 04, 2012 8:04 pm
Nicely done with the spring spreader.. I have to ask this question.. Do Thick brick tires fit on any stock 26 inch frame bike ? That you can leave the fenders on & not have to modify the frame :?:
tanksalot
