Welding At Home...
22 posts • Page 2 of 2 • 1, 2
Re: Welding At Home...
Postby Uncle Stretch on Mon Apr 23, 2012 10:07 pm
This subject comes up all the time. Someone wants a cheap welder to build a few frames.
By the time it gets going instead of the glider the guy wants , the recommendations are a
stealth bomber. I build or have built a bunch of frames with a 110 Miller Cricker FLUX core
welder. I have never had any of them fall apart. My welds look good....not TIG good , but I
can't TIG anyway. Use what you can afford and be proficient with . As you get better buy better
tools. :roll: :roll:
Uncle Stretch
Postby outskirtscustoms on Tue Apr 24, 2012 6:13 am
ezernut9mm wrote:all i have is a stick welder, but it does what i need it to do. i wish i could afford a nice mig so i could really get down to business.
Harbor Freight flux core wire feed MIG $89-$109 depending if they are on sale or not. Mine works just fine. and if you know how to weld it doesn't do too bad. I have laid down some really nice looking welds with it. Biggest thing is PRACTICE and PATIENCE.
Postby yoothgeye on Tue Apr 24, 2012 7:40 am
outskirtscustoms wrote:Harbor Freight flux core wire feed MIG $89-$109 depending if they are on sale or not. Mine works just fine. and if you know how to weld it doesn't do too bad. I have laid down some really nice looking welds with it. Biggest thing is PRACTICE and PATIENCE.
What you have is a flux core wire feed welder, not a MIG, which stands for "metal inert gas" you don't have gas, so just a wire feed.
Postby outskirtscustoms on Tue Apr 24, 2012 10:25 pm
Oh okay. It still works great though.
Postby yoothgeye on Wed Apr 25, 2012 6:16 am
outskirtscustoms wrote:Oh okay. It still works great though.
Agreed! :D
Postby Bloodyknuckles on Sat Apr 28, 2012 8:59 am
A mig welder is one of the best tools you can own. The initial investment can be a little high, but you will find ways to make $ doing odd jobs for friends. I'm not a fan of Harbor Freight flux core welders because the output power can change while laying a bead (poor duty cycle). Small used migs can be bought for around $300. Look for Miller,Lincoln, Hobart, they tend to be better built. If you want to save $ on gas, switch from argon/co2 to co2 only. It will cost about half as much and still give quality welds with a little more spatter.
Bloodyknuckles
Postby Xcruiser on Sat Apr 28, 2012 10:27 am
Philphine wrote:i got one of the cheap harbor freight flux migs. i was kinda spoiled already by being able to to use a better gas mig at work, so i have a hard time with it. if i'm real deliberate with my technique though (such as it is) i can get some decent results. i still tend to take things to work when i want to be more sure of the weld or to reinforce what i've done at home though.
i have to say, i still like having it though. i think if i got one of those auto darkening face sheilds i'd be better with it. with the better one at work i can touch the wire to the work and it won't weld till i pull the trigger. the home one sparks if you do that, so i try to hold it steady, then flip my sheild down to start. i end up being off the mark a lot.
This is the problem with my little HF flux core welder,its live (hot) all the time.Makes it tough to get started with the shield down.
Previous
Return to BIKE TALK
Users browsing this forum: g-ratter and 8 guests
