paint sprayer
14 posts • Page 1 of 1
paint sprayer
Postby Eclipse on Sat Mar 24, 2012 2:02 pm
I want to start painting my own frame. I know I can use the spray cans but I'm under the impression I can have a better result with a paint sprayer. There's all sort of things available out there and I don't know what to look for. If that can help I have a compressor. What do you recommend and what are you using?
For the love of the bike
Eclipse
Re: paint sprayer
Postby jalopyjimmy13 on Sat Mar 24, 2012 9:31 pm
go to harbor frieght they got some desent guns there go check um out
hvlp gravity feed
jalopyjimmy13
Re: paint sprayer
Postby Eclipse on Sun Mar 25, 2012 9:18 am
Do they have an online catalog? I can check em out there as we don't have that kind of store in here. This way I could compare.
Eclipse
Re: paint sprayer
Postby Chips_Mahoy on Sun Mar 25, 2012 12:32 pm
http://www.harborfreight.com
BUILDS IN PROGRESS
Pack Rats
Rad Rot - RRBBO #8 entry
Chips_Mahoy
Re: paint sprayer
Postby bits n pieces on Tue Mar 27, 2012 5:40 am
If you dont have a air compressor, or money to buy a compressor, hose, filters, paint gun, etc , most auto parts and hobby stores have touch up guns with their own aerosal cans. It comes as a kit with a glass jar, lid and sprayer. It cost less than $40 for the kit here and $4.95 each for the sprayers. I usually paint and clearcoat and sometimes can paint a second bike with the aerosal can. You do use automotive paint in the kit.
Nope
bits n pieces
Re: paint sprayer
Postby g-ratter on Wed Mar 28, 2012 6:18 pm
one of the more important aspects of spraying is having a compressor with a big enough tank. I have a 38 gal. tank and it is probably the minimum size to use.
I have a Devilibis gun that a neighbor gave me years ago and as long as I keep it clean it sprays great.
g-ratter
Re: paint sprayer
Postby chimichanga on Wed Mar 28, 2012 7:06 pm
I've used harbor freight spray guns with no problems. :D
but like gratter said having a big compressor is nice to have.
chimichanga
Re: paint sprayer
Postby No Talent Clown on Fri Mar 30, 2012 9:47 pm
I was kinda curous about the colors on the Scwinn American and the single speed road bike with the white tires. I was thinking about painting a project an orange/copper color. What did you use?
uh, what?...
No Talent Clown
Re: paint sprayer
Postby chimichanga on Fri Mar 30, 2012 11:03 pm
No Talent Clown wrote:I was kinda curous about the colors on the Scwinn American and the single speed road bike with the white tires. I was thinking about painting a project an orange/copper color. What did you use?
on the schwinn american i used a green basecoat and house of kolor tangerine kandy over it. and the single spee bike is a silver base coat with house of kolor tangerine kandy.
chimichanga
Re: paint sprayer
Postby No Talent Clown on Mon Apr 02, 2012 10:09 pm
Thanks. Appreciate the info.
uh, what?...
No Talent Clown
Re: paint sprayer
Postby sensor on Tue Apr 03, 2012 9:50 pm
im with jalopyjimmie13 and chimichanga get a harbor freight hvlp gun....theyre cheap work well and if you forget to clean them its not a big deal since you can get another for the price of luch at a burger joint. i would however suggest you get the touch up gun(hvlp as well) since it has a 1.0 needle itll lay down better than the full size one with a 1.4 needle(im assuming you havent painted before) so less chance of runs if you linger in one spot to long....but just be aware....using a gun wont guarantee a good job.....it can make it easier to mess up real fast....youll need to set the gun up correctly, get a good overlap, distance, swing speed,not heel and then there is the prep work that goes into it BEFORE the color comes into the picture....
my suggestion pick up the h.f.gun, get some cheap(if youre in a non regulated area get lacquer paint to practice!) paint start practicing on paper to get a 50/50 overlap(hold it up to a light and see if its 50/50 or is tiger striped) and go from there....lots here paint so if anything comes up just ask there alot who can help
good luck and have have fun!
Re: paint sprayer
Postby nodramabiker on Thu Apr 19, 2012 10:33 am
Ingersoll Rand has a cheap paint sprayer in their online clearance shop. You should check that out: http://shopir.com/SprayGun-GravityFeed- ... l9115.aspx
nodramabiker
Re: paint sprayer
Postby big kountry on Thu Apr 19, 2012 12:36 pm
I use a model paint gun set up it has a small compessor an paint isnt $80 bucks a gallon but this will slso be my first bike I've painted so I'll let you know how it works but it works great on my R.C toys
Kountry Kustoms
Nuttin Fancy
Big Dawg Eliminator
big kountry
Re: paint sprayer
Postby gcrank1 on Thu Apr 19, 2012 3:20 pm
I dont think Id 'want' to paint a bike with my old Pasche (sp?) airbrush, but could probably do it; probably wouldnt have to worry about runs too much, just keep moving. Lots of light coats, not unlike a spraycan, and the paint gets there.
gcrank1
Return to HOW TO
