Skinny tired Cruiser Code named Greenie:o)
32 posts • Page 2 of 3 • 1, 2, 3
Re: Skinny tired Cruiser Code named Greenie:o)
Postby Powder Keg on Sun Mar 25, 2012 3:15 pm
Today I started masking off my design. I had an idea to make a cardboard template that I could trace my design onto the masking tape. I stuck the masking tape to some waxed paper, traced my template, then cut out the design. My way of thinking was that this would be perfect. Not so! The wax paper didn't have enough wax on it or the tape was too sticky? The tape would tear the paper if you could find an edge to separate the two. Grrrr.
I ended up using a scrap of plastic that I had lying around. I marked my design out and cut it out with a razor knife.
This actually worked very good. After a couple I started to get a little fancier with my design.
After it was all masked I sprayed my Sublime Green Pearl on. I took a lunch break and let the paint set up a bit. After lunch I unmasked everything. Here is a sneak peak at the fork.
I'll be able to wet sand it and squirt on the clear coat tomorrow after work:o)
~Wes~
“Those that say it can't be done should get out of the way of those doing it”
Powder Keg
Postby Doon on Sun Mar 25, 2012 4:19 pm
Looking good! i love the color.
Doon
Postby Powder Keg on Sun Mar 25, 2012 5:47 pm
Thanks Doon!!!
Here's another peak:o)
This was pretty fun to paint. It's went pretty good so far. It takes a lot of work to make sure everything comes out nice. Especially the masking of the designs I put on. I'm using a $10 gun from harbor freight and pre-mixed paint. I can't wait to get the clear on:o)
~Wes~
Powder Keg
Postby billywilly on Sun Mar 25, 2012 6:42 pm
That looks awesome so far. I'm excited to see a picture of the frame and fork together. How did you have this set up to paint it? I'm thinking about painting my bike but I want to figure out a rack that will hold it up and allow me to paint all sides very easily.
billywilly
Postby Powder Keg on Sun Mar 25, 2012 7:25 pm
Its hanging from 2 strings. 1 through the seat tube and another through the steering tube. The string is tied around a block of wood to keep it from pulling through. You just have to be sure to get underneath. I think I only missed one spot and it's on the forks. It will be covered by the bolt that goes through the spring. A rookie mistake:o)
Glad you like it:o)
~Wes~
Powder Keg
Postby Powder Keg on Mon Mar 26, 2012 7:53 pm
I was able to get the clear shot on after work today. It turned out pretty nice. Bikes are hard to paint. The sun was going down in this picture:o(
I'll start putting things back together Thursday or so. I want the paint to cure a little. I ordered some Green pedals. They should be here tomorrow. All I have left to buy is a chain and a kickstand.
~Wes~
Powder Keg
Postby Powder Keg on Fri Mar 30, 2012 7:56 am
Almost done\o/ I'm waiting on a chain and my pedals still. I'll get the cranks in today.
~Wes~
Powder Keg
Postby Dr. Tankenstein on Fri Mar 30, 2012 8:20 am
I like it, it has a 'modern' look while still being a 'vintage' bike.
Great work on it!
Cheers,
Postby kingfish254 on Fri Mar 30, 2012 9:28 am
Sweet looking ride! Makes me want to go buy some lime sherbert.
Postby jaysmo on Fri Mar 30, 2012 10:50 am
looks great very nice bike .....
jaysmo
Postby Powder Keg on Fri Mar 30, 2012 5:45 pm
The cranks are installed. I'm waiting on my new pedals and green chain:o( I found some green reflectors and light I'm going to get. I should have ordered stuff sooner.
Thanks so muck for the compliments!!!
~Wes~
Powder Keg
Postby Powder Keg on Sat Mar 31, 2012 6:17 pm
My pedals arrived\o/
Today I cut out some white oak to make the back rack out of. Here I'm checking things out. Dig the pedals:o)
I'm liking the looks of things. I want to try something with the seat though.
Here I have the boards shaped and sanded smooth. I'll start applying the finish tonight. It will probably take five or six coats of Tung oil.
I can't wait for that chain to get here:o)
~Wes~
Powder Keg
Postby MazdaFlyer on Sat Mar 31, 2012 6:32 pm
Nice bike, I like the green and white.
Kustom Coaster III viewtopic.php?f=75&t=72035
MazdaFlyer
Postby Powder Keg on Thu Apr 05, 2012 8:24 pm
Got my Green chain today and installed it\o/ The bike works/looks great!!! The kickback hub is kind of fun. I'll post a few more pictures this weekend. I have a little art work planned for the wood rack. I have a lot going on right now:o)
~Wes~
Powder Keg
Postby MplsCoaster on Fri Apr 06, 2012 9:37 pm
Really Sharp Bike! Paint work looks great!
Users browsing this forum: dracothered and 10 guests
