Big Daddy"Rat Fink"Scooter New taillight Advertising RRB!!Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorIm getting anxious too! This is so awesome!!!
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorWell since Im waiting for my sprocket to get here I ordered a expansion chamber Its the only way to run a 2 stroke and they look and sound cool! This one is closer so I hope they show up at the same time.
![]() "If you can't fix it with a Hammer then you must have an electrical problem" my Apprentice
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorMy sprocket came in now i can lay it all out and get going! I hope the exhaust comes today if so I can probably get it on the road this weekend!
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorI got some work done today! I trimmed down the tank,cut and moved the petcock from the rear to the front,and patched the hole where cut it out. I think it looks a lot better this way. I put the sprocket on the wheel and im changing the motor mounts so it all jives together.The pipe came in and Im going to cut and reweld the flange so I can clock it where I want it,They come ran close to the motor for crank clearence but I want to run it out side the deck so ill cut it and make it work.
![]() ![]() ![]() ![]() "If you can't fix it with a Hammer then you must have an electrical problem" my Apprentice
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorI welded up the motor mounts so I think im done for today!
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorI made a exhaust manifold so I can clock the expansion chamber where I want it,I think it should work allright....
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorYou keep gettin´cooler and cooler man...
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorGetting closer,I ran my cables and wires and finished the motor mount!
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorWow now that's doing it right. If it's not already running, you are going to be stoked when you ride it the first time.
In case of zombies, I'm tripping you.
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorThat's so rad-hurry up already so we can see the grand finale
Awesome work man!
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorWell I got everything mounted and ready for its maiden voyage and FAILURE!!!! MY gas tank leaks like crazy and when I popped the clutch and it came to life it folded my motor mount
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorI should have got some pics of the damage but I was irritated so I just tore it apart and fixed it.I made it like a I beam and test ran it without a tank and it runs good!!!Now Ill take it apart and clean and paint it while I wait for the new tank...
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorLooking great! One question thou, how will you prevent the ugly leg burns?
I think its long enough there should be no leg burns I hope! "If you can't fix it with a Hammer then you must have an electrical problem" my Apprentice
Re: BigDaddy Scooter "tribute to Ed Roth" Gettin a 80cc MotorThis after noon I figured I would get a little body work done....Since the fenders got dented and need a repaint I thought I would go ahead and add 8" to the front fender,make it match the rear ya know...I should have done this the first time!
Who is onlineUsers browsing this forum: snarehead123, theCROWcook and 6 guests |
