Sears Spyder Rat: RIP (see Chimera Chopper)
38 posts • Page 1 of 3 • 1, 2, 3
Postby IronDio on Mon Feb 06, 2012 9:58 pm
So, traded some truck parts for a couple of bikes. Got this Sears Spyder out of the deal...
I also got a Rage Empire bike with decent Kenda Flame tires.
The flames were a bit big for the bike, so, I robbed the triple tree fork and used some coaster brake arms to move the rear tire back and up a bit...
...only one bolt in there for now, but we're just mocking this up. Swapped the fork and put the apes on the new fork.
Not bad for an hour of work if I do say so myself! (glad I soaked it down with penetrating oil when I got it home!)
Going to do something with the seat next and strip those ridiculous decals off the fork next
I have 3 favorite colors...flat black, chrome, and rust
http://www.facebook.com/SW6thCustomsAndClassics
IronDio
Re: Quickie Spyder "Rat" Build
Postby Jake Sensi on Mon Feb 06, 2012 10:38 pm
Nice start! Get ta buildin'!! Peace
Ride and Rat On
Jake Sensi
Postby Mugen_Stumpo on Tue Feb 07, 2012 12:32 pm
already like it a lot :D
PabloAntonio wrote:That is the junkiest pile of bolts of all time. Amazing and awesome. I love it.
Mugen_Stumpo
Postby MplsCoaster on Tue Feb 07, 2012 7:17 pm
Cool Rat!
Postby IronDio on Tue Feb 07, 2012 9:54 pm
Spent another hour on it tonight. Got the rear axle extenders drilled to be permanently mounted, got the fork into position, and played with the seat position. I wanted to get it further back and LOW...
I like the position a lot. It kind of flows with the frame. I drilled out the mount for the seat and moved it forward a couple of inches, then I pulled out the seat post and mounted the seat right to the clamp. Now, I just have to shorten the sissy bar and drill new holes to mount it to (or near) the rear axle...I might turn the clamp around to move it back a little more even, now that I look at it again :)
IronDio
Postby kingfish254 on Thu Feb 09, 2012 5:42 pm
I am digging this build.
MO FATTA MO BETTA!!!!!!!
Postby IronDio on Thu Feb 09, 2012 9:53 pm
Doing this bike hour-by-hour, an hour here, an hour there...So, in last night's episode, I wire wheeled the sissy bar, cut it to length, and drilled the new holes. Then I wire wheeled the banana seat, and glued foam to the pan. In tonight's episode, I finished covering the seat, mounted the shortened sissy bar, and mounted the kickstand off the Rage.
I'm pretty happy with the seat! It was my first try at upholstery work, and I think it looks pretty cool. Used a leather jacket a guy gave me at work.
So, I'm pretty much done with mocking it up. I was looking at the paint, and it's pretty bumpy, and since this is a rat, I'm thinking it might look pretty cool with a cast iron finish. Still gotta work on getting those decals off the fork...
IronDio
Postby jalopyjimmy13 on Thu Feb 09, 2012 10:47 pm
kool :D
jalopyjimmy13
Postby IronDio on Sat Feb 11, 2012 8:27 am
Spent some more time on it last night. I scrubbed it down and painted it cast iron grey. I'm really liking the color! Just have to grease the crank bearings and mount the rear fender now. Going to try some decal stripper on the forks...those things are really on there :(
IronDio
Postby jalopyjimmy13 on Sat Feb 11, 2012 10:38 am
use a lil heat blow dryer propain torch always works great
jalopyjimmy13
Postby SCHWINNRAY69 on Sat Feb 11, 2012 10:47 am
Looks great! :D The fat tires and silver paint make this bike 8)
Postby IronDio on Mon Feb 13, 2012 9:05 pm
Mounted a rear fender and added a reflector to that. Fully inflated the tires, now I have a rub issue on the seat stays, so I'm going to have to tear it down and spread it a little for clearance.
Thinking it needs a headlight now ;)
IronDio
Postby MplsCoaster on Tue Feb 14, 2012 12:12 pm
Looking good!
Postby IronDio on Tue Feb 14, 2012 1:48 pm
picked up a 4-1/2" utility light at work and mounted it...I think it's the perfect size!
Now, if I could just get a FUNCTIONING headlight...LOL
IronDio
Postby IronDio on Fri Feb 17, 2012 8:37 am
Here's a side shot of the bike with the headlight.
Found a small LiPo battery pack on ebay I'm going to experiment with for a power source. If their specs are correct, I should be able to run the light for 2.5hrs on a charge...but we'll just have to see. It's on the slow boat from Hong Kong, so, now we wait :(
IronDio
