boardtrack racer datona style"ROOTBEER FLOAT"
51 posts • Page 2 of 4 • 1, 2, 3, 4
Re: boardtrack racer datona style"ROOTBEER FLOAT"
Postby lilmikew86 on Sat Dec 10, 2011 11:15 pm
well this is the bottom of the frame where the engine plates bolt to and where the freeze plugs came in handy got them tacked just got to weld and blend them now!
lilmikew86
Postby Slick65 on Sat Dec 17, 2011 7:19 pm
Do you mind sharing how you did those bends? As a garage enthusiast myself that is one of the next tools I am looking to aquire. Without doing a smokey bleach burnout on my wallet. :lol:
Slick65
Postby lilmikew86 on Sat Dec 17, 2011 10:37 pm
well i used a torch and the vise to two do the real tight bends bending two tubes at one time to get them symmetrical and sum were bent by hand aroung home made jigs and the rolling bends were done in a press moving the tube a inch at a time till i got the shape and radious i wanted .i have a hydraulic tubing bender but i wanted to do this project more by hand a lil old skool.
lilmikew86
Postby WAYNE TACO! on Sat Feb 25, 2012 8:54 pm
I like root beer floats.
Stay AWESOME!
WAYNE TACO!
SNUG LIFE!
WAYNE TACO!
Postby lilmikew86 on Sat Mar 17, 2012 7:59 pm
well after the holidays and sum familly issues im finally able to get back to work on this ,so as of now im working to get the leaf spring fork completed after that mounting the seat with sum kind of adjustment system as there is no seat post like most bikes then it will be ridealbe :D Image
lilmikew86
Postby lilmikew86 on Sat Mar 17, 2012 8:01 pm
lilmikew86
Postby lilmikew86 on Wed Mar 21, 2012 9:50 pm
lilmikew86
Postby lilmikew86 on Wed Mar 21, 2012 9:52 pm
gettin ahead of myself but got this at work today for dress up
lilmikew86
Postby lilmikew86 on Mon Apr 02, 2012 10:52 pm
still got to make the brace but this is water twist all done by hand!
lilmikew86
Postby lilmikew86 on Mon Apr 02, 2012 10:55 pm
also my front legs for my leaf spring fork will be water twist
lilmikew86
Postby lilmikew86 on Mon Apr 02, 2012 11:20 pm
GE fog lamp ill be using as my head light .still works!
lilmikew86
Postby lilmikew86 on Sat Apr 28, 2012 12:57 am
welded nuts in the fork tubes for the tripple tree plate grinded them smooth
lilmikew86
Postby lilmikew86 on Sat Apr 28, 2012 12:59 am
lilmikew86
Postby lilmikew86 on Sat Apr 28, 2012 1:00 am
lilmikew86
Postby lilmikew86 on Sat Apr 28, 2012 1:05 am
leaf spring assembly i put together still needs some cleaning up,drilled the center out of some solid aluminum stock to be as a shackle/bearing
lilmikew86
Return to BUILT FROM SCRATCH
