boardtrack racer datona style"ROOTBEER FLOAT"
51 posts • Page 1 of 4 • 1, 2, 3, 4
boardtrack racer datona style"ROOTBEER FLOAT"Hello every one I am new to this site and just wanted to share my most recent build that I'm working on to unveil at Sacramentos 2012 Cyclefest. This will be a board track inspired build with a twist and is not a replica of any other style but of my own design. It will have a little bit of rat style like if someone found a late 1900 motorcycle/boardtrack racer in the 60's n 70's and did it up to be a showrod/hotrod. Pictures will be added little by little as I get further into the build.
Re: boardtrack racer datona style"ROOTBEER FLOAT"alright on the bottom part of the frame the engine plates bolt on wit 3/8 bolts to keep the frame from crushing i welded in sum small tubing as a sleeve Last edited by lilmikew86 on Wed Dec 07, 2011 10:23 pm, edited 1 time in total.
Re: boardtrack racer datona style"ROOTBEER FLOAT"HMMMM, interesting. I am watching this.
Outlaw Outlaw Bikes
BURRITO'S RULE
Re: boardtrack racer datona style"ROOTBEER FLOAT"im glad your interested outlaw.
ok so here is the frame caps (freeze plugs i bought at work for like 30 cents a peice) that i will weld on the the ends of the frame to cap it they are dome shape as well so it will look cool too. They are galvanized so i will grind the edges clean before welding also theese plugs are 1 1/4 the same size of the tubing so for 60 cents it fits perfect and saves me time. this is the frame gusset for the head tube and working on the rear drop outs still gota fab the built in chain tensioner
Re: boardtrack racer datona style"ROOTBEER FLOAT"Really nice start on a custom. Makes me want to build something.
Ok if I hang that one over there, and slide this one over here
maybe one more will fit right here!
Re: boardtrack racer datona style"ROOTBEER FLOAT"this is an interesting build, I like it so far. did you cut the tube then put your drops in the slots or just cut the drops. I like to slot the tubes an put whatever in then weld. either way, looks good. you sure ya never did this before. ya do nice work. still watchin.
Outlaw Outlaw Bikes
BURRITO'S RULE
Re: boardtrack racer datona style"ROOTBEER FLOAT"thanks muller and stretch. actually i cut two slots into the drop out instead of cuttin out the whole chunk out of the drop out and slid the tube over that made it really strong that way and could of rode it wit out the drop outs bein welded.kinda had to press them on lol really tight fit.oh and this is my first frame build ive made alot of stuff but not a frame so i said why not,so this will be the first to many im alredy thinkin of the next one for my wife.Thanks for lookin
Re: boardtrack racer datona style"ROOTBEER FLOAT"well i almost got the frame all welded up just a few more seams to seal and straight as a arrow not to shabby wit out a jig but the level,protractor and angle finder were my best freinds for a few days .i think after i finish this one i might start a frame jig ,might make tings alot more easy for future frames.well here it is enjoy now i gota finish the forks and tank!
Re: boardtrack racer datona style"ROOTBEER FLOAT"yes its flux core wire and ugly but penetrates really well till i get a new bottle for sheilding gas but wont really matter cause i will be molding the welds with body filler to give the frame a real smooth and seamless look
Re: boardtrack racer datona style"ROOTBEER FLOAT"also have these streamline pedals ill be using
Re: boardtrack racer datona style"ROOTBEER FLOAT"really nice. thats even a better idea how ya did the dropouts. will have to try that one. thanks.
Outlaw Outlaw Bikes
BURRITO'S RULE
Re: boardtrack racer datona style"ROOTBEER FLOAT"no problem outlaw
Re: boardtrack racer datona style"ROOTBEER FLOAT"ok here is the begining of the tank although this bike will be ridden the tank will be functional if i ever want to mount a motor.the tank is half way done but this is the only picture i have at this time sorry i will update as soon as i can
Who is onlineUsers browsing this forum: No registered users and 1 guest |
