Keg Trike
37 posts • Page 1 of 3 • 1, 2, 3
Keg Trike
Postby pvwacko on Sat Oct 01, 2011 5:25 pm
I had a bunch of parts laying around the garage that needed to either be sold or put to use and because I sold my other custom trike I figured I would build another. Since I'm using the rear end from a production trike I guess this doesn't belong in the scratch built collection... so many shades of grey! Anyway, started with a keg gas tank and a tractor seat I picked up at a swap meet. Picked up an off brand trike from CL and pulled an old rock shox fork and a 3 speed CB hub out of the stash to get started. Thinking about taking this to Tour De Fat in Tempe this year if I finish it in time...
The entire front end is going to the parts pile... i figure that all I need to do to get it back on the road is build a rear triangle!
the use full bits... including nice chrome 24" wheels waiting for 24x3 tires!
The direction I'm planning to go. Tank is going to be all integrated sheet steel. Want to try some crazy paint this time.
Frame is in the jig so I'm just waiting on monday to buy some steel.
Wacko's Garage http://www.wackosgarage.com
Intro http://www.ratrodbikes.com/forum/viewtopic.php?f=9&t=19496
pvwacko
Re: Keg Trike
Postby Peatbog on Sat Oct 01, 2011 7:54 pm
Cool.
Re: Keg Trike
Postby kingfish254 on Sat Oct 01, 2011 8:29 pm
Very cool! I am looking forward to following your build.
I like the keg (look at my BEER RUN build).
I like the chopper trike idea. I want to marry the back end of a 70s WF Trike that I have to a modern Nirve Clutch kids chopper frame. I also want to mount Harley tires on two OCC StingRay Chopper rims (see my Fugsley build) for my back wheels. I would like to figure out how to use an old SA 3speed hub as well, so that I can make a cool stick shift.
Re: Keg Trike
Postby pvwacko on Mon Oct 03, 2011 3:09 pm
Decided to work in a girder fork to this build. Started to tack the fork legs together and get my pivot points worked out. Have to go buy welding gas tomorrow for all the welders before I can continue. Also on the list for tomorrow is the steel tubing for the frame. The last thing I picked up is a piece of an old leaf spring to cut down and use to mount the tractor seat. More updates tomorrow.
pvwacko
Re: Keg Trike
Postby Fireproof on Mon Oct 03, 2011 3:39 pm
COOL!!!!! After what ya did with yer last trike, I'll certanly be watching this build! 8)
My Intro <((><
Matt 13:36-43
Fireproof
Re: Keg Trike
Postby pvwacko on Tue Oct 04, 2011 10:05 pm
Bought steel tubing and welding gas today but when I got home I didn't have enough room to work in the garage. The remainder of the day was spent cleaning the garage and making room for me to work. I did have a chance to play around with the rake and trail calculations... these were done with the aid of the driveway lines. I moved things around until I got everything right where I wanted it. Measurements were then taken of the angle and the height of the steer tube so I could replicate this on the jig.
At the hardware store I took measurements of some coolers to see if I would be able to fit one in the keg... have to make that space usefull. the only question now is if I can fit a 12 pack or a 30 pack of cans!
Last a little teaser of the paint! I'm messing around with some classic paint styles for this frame. Lace paint work with metal flake is going to be so much fun to lay out. Here is a piece of cardboard that I did my experimenting on.
pvwacko
Re: Keg Trike
Postby pvwacko on Wed Oct 05, 2011 12:10 pm
The Girder is all finished except for the shock tabs and final assembly with the plastic washers.
I also figured out a really cool location for the three speed shifter!
pvwacko
Re: Keg Trike
Postby pvwacko on Thu Oct 06, 2011 3:50 pm
Bulk of the frame fabrication is finished... Still need to weld on the side panels of the tank and clean up the frame. Worked with the spring steel and cut it down to size but it had no flex with my body weight on it. Instead I'm going to hinge and spring the seat. I'm also dropping the tank down as far as I can.
pvwacko
Re: Keg Trike
Postby jaysmo on Thu Oct 06, 2011 4:37 pm
this taking shape very well..and fast.....keep it going...
jaysmo
Re: Keg Trike
Postby kingfish254 on Thu Oct 06, 2011 6:08 pm
You do some beautiful and fast work!!!
I love the thumb shifter location!!!!
Re: Keg Trike
Postby Sinner4 on Thu Oct 06, 2011 7:01 pm
I want a fork setup like that. Nice job
Some people call me Macgyver
Sinner4
Re: Keg Trike
Postby pvwacko on Thu Oct 06, 2011 8:46 pm
Just ordered a full set of these electra tires! Almost twice what I paid for the trike...
pvwacko
Re: Keg Trike
Postby Gdcast on Fri Oct 07, 2011 10:34 am
Looking Goooood :mrgreen:
Wanna see my rides? :
Gdcast
Re: Keg Trike
Postby jaysmo on Fri Oct 07, 2011 11:29 am
pvwacko wrote:Just ordered a full set of these electra tires! Almost twice what I paid for the trike...
I was looking at them on amazon last night...i want to see how they work for you....
jaysmo
Re: Keg Trike
Postby pvwacko on Fri Oct 07, 2011 12:18 pm
jaysmo wrote:I was looking at them on amazon last night...i want to see how they work for you....
I just checked amazon and ordering from Electra direct was cheaper and the shipping is free for orders over $50
pvwacko
Users browsing this forum: JohThomas Sorrels, paulnb57 and 7 guests
