Making My Own Head Badges
77 posts • Page 2 of 6 • 1, 2, 3, 4, 5, 6
Re: Making My Own Head Badges
Postby XC204 on Tue Sep 13, 2011 11:06 am
I checked the prices on materials and for the price of the material for getting started Terry at Jones & Son can do 2 badges for you depends on how many you want to do I guess pretty cool process though.
viewtopic.php?f=2&t=31195&p=401398#p401398
Gary
lots of bikes
Tig/stick/plasma hobby welder
XC204
Postby axsepul on Tue Sep 13, 2011 1:33 pm
cool
axsepul
Postby linksandkinks on Tue Sep 13, 2011 9:21 pm
thanks for the reply, i think i was reading too much into it lol i have an idea im going to try with some aluminum and my vinyl cutter, ill post pics when im done
linksandkinks
Postby Chris Crew on Wed Sep 28, 2011 11:47 am
"Acid in water--like you oughta'" was my HS Chemistry Teacher's mantra.
Nice work.
Chris Crew
Postby jalopyjimmy13 on Tue Oct 11, 2011 8:48 am
i see club badges in our future thanx guys
jalopyjimmy13
Postby axsepul on Thu Oct 13, 2011 1:33 pm
I decided to try this out but with a vinyl cut out. I used gray vinyl since it was already in the plotter.
Its in the acid right now. I'll let you know how it turns out
axsepul
Postby axsepul on Thu Oct 13, 2011 2:03 pm
So after 20 minutes I didn't see much etching so I added another 1/2 cup of acid and I check in a little spot that I had painted black
Not bad but I want more depth so in it goes another 10
axsepul
Postby axsepul on Fri Oct 14, 2011 9:51 am
i got drunk yesterday and forgot to finish this.
so after i added another 1/2 cup of acid i was pleased.
now i said, what if i add some color since the part that was going to show was still covered
white primer
a little rattle can color blend, red and cream
now i have a problem because i just cant wait until it dries, so while the paint was wet i cut it
removed the vinyl and about a million fingerprints later
so i was not feeling the fingerprints so i removed all the paint
maybe next time i'll cut it and then paint it!
axsepul
Postby InTheFade on Fri Oct 14, 2011 10:20 am
Great Turorial, Thanks! I didnt notice anyone else mention this but PC Board etching solution that is available at radioshack will do the same thing to brass and copper as the muriatic. Also is slightly less dangerous to work with... However you still want to have good ventalation and wear gloves as PCB(Ferric Chloric acid) will also still burn bare skin.
InTheFade
Postby CycleTruck on Fri Oct 14, 2011 2:32 pm
Great job axsepul!
Give me a spoke and I'll build a bicycle around it.
CycleTruck
Postby axsepul on Fri Oct 14, 2011 10:11 pm
CycleTruck wrote:Great job axsepul!
Thanks! I made 4 today just for fun but should be good for awhile cause cutting that outer edge with the dremel really takes a lot. Maybe with a really thin band saw would be a lot easier.
axsepul
Postby B607 on Sat Oct 15, 2011 3:35 am
Looks great! Another badge maker in the ranks. You young guys with your high tech stuff are pretty clever. 8) Gary
Dripping with Sarcasm...
B607
Postby Motopecane on Mon Oct 17, 2011 4:37 pm
For cutting out the outer edge you could always us a nibbler tool, then clean it up with a dremel. They work great for thin soft metals like brass.
http://www.harborfreight.com/nibbling-cutter-97636.html
Motopecane
Postby Bize on Tue Oct 18, 2011 1:51 am
B607 wrote:You young guys with your high tech stuff are pretty clever.
LOL and I'm at the in-between age where I'm not quite old enough to have a wealth of tried and tested, old school knowledge nor am I quite young enough to take all the new technology for granted. I guess the upside is I find learning the traditional methods and the new methods equally exciting :p
Bize
Postby axsepul on Fri Nov 04, 2011 2:22 pm
its true, i'm addicted to making badges now. here are two i did today. the pioneer headbadge and the sporter
i will also like to add to this tutorial that i've found out that just because you dip two badges at the same time it doesnt mean that it will etch both at the same time. the more the badges the more time it takes to etch and i've also found out that to get a really nice deep etch it will take about an hour for one plus it needs to be agitated to achieve a nice deep etch
axsepul
Return to HOW TO
