Yard Ornament -7/31 AS GOOD AS IT'S GONNA GET!
89 posts • Page 4 of 6 • 1, 2, 3, 4, 5, 6
Re: Yard Ornament - Lights Added 6/30
Postby scott brownsey on Thu Jun 30, 2011 2:59 pm
sweet bike front end is awsum great job
scott brownsey
Postby Zombie King on Thu Jun 30, 2011 8:23 pm
one of the best looking springer forks i have seen in a long time. excellent execution , fantastic looks that forks has it all simplicity at its finest..........
The ones that keep it alive will one day received glory in heaven.......
Zombie King
Re: Yard Ornament -Drillin holes & makin guard brackets
Postby z-bikes on Thu Jul 07, 2011 7:31 pm
I thought the bike was gettin a little heavy so drilled some holes in the spring fork dropouts. Good for maybe 2 grams weight loss?
Had to make chain guard brackets. The first was pretty conventional: Image
The second slightly more complex. Started with this:
Made this:
Fits like this:
Just gotta finish drillin some holes to attach the bracket to the guard. I'm a little nervous about welding the two aluminum parts with a torch and some rod. A little too much heat and the guard is toast
z-bikes
Postby tin machine on Thu Jul 07, 2011 7:34 pm
awesome build ..great work !!!!!! this is a winner :mrgreen:
Re: Yard Ornament -Drillin holes & makin guard brackets 7/7
Postby Craiggo on Thu Jul 07, 2011 10:41 pm
i cant fathom your incredible ability to make your own parts, i just rely on what i may have thrown on my shelf over the years :mrgreen:
-Mike Wolfe
Craiggo
Postby imagearchy on Fri Jul 08, 2011 12:41 am
z-bikes wrote:Just gotta finish drillin some holes to attach the bracket to the guard. I'm a little nervous about welding the two aluminum parts with a torch and some rod. A little too much heat and the guard is toast
i wouldn't weld it. It's only holding up the chain guard.....maybe just a tac?
iMaGeArChY E.· ` ' / ·. F
imagearchy
Re: Yard Ornament -In Primer & Paint Color Preview
Postby z-bikes on Wed Jul 20, 2011 6:52 pm
I've been busy on the bike but haven't posted in a while. Been working on the paint and prepping all the parts for hopefully the final assembly. The frame had a lot of pitting in the metal so I had to use a filler primer and do a lot of wet sanding to get it ready for paint. Here it is in the back yard where I wet sanded it.
Hangin in the garage ready for the final coat of primer.
In primer and ready for paint!
Sneak preview of the color.
z-bikes
Postby Jake Sensi on Wed Jul 20, 2011 6:58 pm
AAAARRRGGGHH!!!(CHARLIE BROWN SCREAM) I WAS WAITING FOR THIS AND NOW IT'S ON...GET TA PAINTIN'!! PEACE
Ride and Rat On
Jake Sensi
Postby kingfish254 on Wed Jul 20, 2011 6:58 pm
I'll go ahead and say it before anyone else does.
I am Green with envy. :roll:
Postby yoothgeye on Thu Jul 21, 2011 7:44 am
kingfish254 wrote:I'll go ahead and say it before anyone else does.
:roll:
Postby Critter1 on Thu Jul 21, 2011 8:51 am
Excellent fab work on the bracket! Thats what its all about! You made it!! Can't buy that at your LBS!! :D
z-bikes wrote:Image
Justin
Critter1
Postby jaysmo on Thu Jul 21, 2011 8:55 am
wow this is taking shape very nicely but i did have a question on the trus rods you made you used a hollow ss steel rod?? i love the direction your going with this and everything you have done keep it up ...
jaysmo
Postby z-bikes on Thu Jul 21, 2011 9:14 am
The truss rods are made from 1/2" Stainless tubing, the kind used for hydraulic or pneumatic lines in industry. A 7/16" fine thread tap worked perfectly to tap the top for the studs I made out of 7/16" bolts. I cut a screwdriver slot into the top of the studs so you can turn them in or out of the truss rods before tightening the lock nuts. This changes the overall length of the truss rods and allows you to center the wheel in the fork.
z-bikes
Re: Yard Ornament -7/23 New Parts & Ready for Assembly
Postby z-bikes on Sat Jul 23, 2011 4:02 pm
Worked on buffing the new parts to get them ready for installation. Not a fun job! Here's a picture of the new parts made for the build. Most are ready to be installed, some need final buffing. The new SS seatpost has to be bent yet but I'm waiting for the seat to arrive before I do it. It's longer than normal so it can be raised for longer rides.
Ran the new springs and the bearing cups through the buffer too.
Buffed the raised portions of the chain guard, then painted the rest. Have to clean up where the paint got under the tape. I used Thin Line Tape and wasn't too happy with it.
Got my new grips today. I'm liking them!
z-bikes
Postby kingfish254 on Sat Jul 23, 2011 4:07 pm
I'm Gumby Da.mnit! :lol:
Return to BUILD OFF #6
