Yard Ornament -7/31 AS GOOD AS IT'S GONNA GET!
89 posts • Page 2 of 6 • 1, 2, 3, 4, 5, 6
Re: Yard Ornament
Postby Gdcast on Fri Jun 17, 2011 9:11 am
Great bike!
Looks like the original paint is still there under the house paint.
Wanna see my rides? :
Gdcast
Re: Yard Ornament
Postby ratina on Fri Jun 17, 2011 9:41 am
carefully grind that weld off, then hope its not too rusty to come apart
Ben
Patina + Rat = Me
ratina
Re: Yard Ornament - Fork mock up
Postby z-bikes on Sun Jun 19, 2011 9:44 am
Got the fork mocked up on the bike. Still need to drill the axle holes in the new front dropouts. Decided to go with a double spring arrangement for something different. Lots of details to work out Crappy picture, should have moved it for a plain background so details could be seen.
z-bikes
Re: Yard Ornament
Postby z-bikes on Sun Jun 19, 2011 7:04 pm
Drilled holes and mounted the wheel for a quick look. I likes it! Lot's of finishing to do but you get the idea.
z-bikes
Re: Yard Ornament
Postby scott brownsey on Sun Jun 19, 2011 7:58 pm
awsum bike so far :mrgreen:
scott brownsey
Re: Yard Ornament
Postby imagearchy on Sun Jun 19, 2011 11:23 pm
i like the air cleaner knock off bolts as axle nuts. did you have to drill and tap them to fit? i tried to fit one on the seat clamp on my goodyear but the threads were too small. and nice stance!
iMaGeArChY E.· ` ' / ·. F
imagearchy
Re: Yard Ornament
Postby z-bikes on Mon Jun 20, 2011 4:59 am
I bought those nuts years ago off ebay and they were made for bikes, at least that's how they were advertised. They were already tapped for 5/16 - 24. I had them on a 50's Hawthorne rider but thought they were perfect for this bike so I switched them.
z-bikes
Re: Yard Ornament
Postby Gdcast on Mon Jun 20, 2011 7:24 am
Looking great!!!
Gdcast
Re: Yard Ornament
Postby scott brownsey on Mon Jun 20, 2011 9:43 pm
what size and brand is the rear tire
scott brownsey
Re: Yard Ornament - tire size
Postby z-bikes on Tue Jun 21, 2011 5:31 am
It's a CST Cyclops 26 x 2.4 from Niagra Cycles. Cheap @ $13.92.
http://www.niagaracycle.com/product_inf ... _id=435479
z-bikes
Re: Yard Ornament - Updated 6/22
Postby z-bikes on Wed Jun 22, 2011 7:34 pm
MY RATROD HAS A STIFFY!
z-bikes
Possible H-Bars & Stem
Postby z-bikes on Wed Jun 22, 2011 7:39 pm
Not sure yet if this is the direction I wanna go. Just trying em out.
z-bikes
Re: Yard Ornament - Paint Stripped!
Postby z-bikes on Fri Jun 24, 2011 7:06 pm
Worked on removing the paint, took more steps than I expected. I initially tried sandblasting but it was going too slow so I resorted to spray-on stripper. That worked quite well. Used a scotchbrite pad and soapy water to remove any loose residue and then went back to the sandblast cabinet. I'll probably spray it with WD40 to keep the rust at bay until I'm ready to paint.
With the paint stripper working
Excess scraped off
Clean and ready for paint
I might prime it instead of the WD40, just something to keep the rust off while I finish the mock up. Don't want to paint until all of the parts are fitted and adjusted
z-bikes
Postby imagearchy on Sat Jun 25, 2011 1:21 am
I would clear it right now! or Wd40 ? all metal with the bronzing on the joints makes a good look!
imagearchy
Postby Wildcat on Sat Jun 25, 2011 5:40 am
I'll second that, those joints look great.
Wildcat
Return to BUILD OFF #6
