The "Algonquin" (short video added)
39 posts • Page 1 of 3 • 1, 2, 3
Postby Lugisland on Sun Apr 03, 2011 3:27 pm
I'm starting a new build I'm calling the "Algonquin". It will be motored bike powered by a Grubee Super Rat. I'm starting out with a Wards Hawthorne twin top tube frame (can anyone date this frame?), Schwinn style springer with brakes, and some Brown Fat Franks. I mounted the Franks on a new set of heavy duty 12ga spoked wheels. I won't be using the kit supplied tank because... well I think they're ugly. I've got a couple of different tank ideas I've been kicking around, but I haven't decided which one yet. So far, I've gathered up most of the parts, and decided on colors: Chrysler 300c Cool Vanilla for the frame, and Cummins diesel engine beige for the motor and some of the small parts. The frame is brazed so I'm making some gussets to strengthen it up near the headtube, seattube, and rear dropouts. I found a local tig welder who does nice work for cheap to weld them in. Here are some pictures. Tom
{DEVIANT} http://www.ratrodbikes.com/forum/viewtopic.php?f=68&t=61058
Lugisland
Re: The "Algonquin"
Postby gowjobs on Sun Apr 03, 2011 3:35 pm
Name of your bike just gave me a flashback to "Elvira, Mistress of the Dark".
Cool beginning.
Dave "Gowjobs" McGowan
gowjobs
Re: The "Algonquin"
Postby SCHWINNRAY69 on Sun Apr 03, 2011 3:40 pm
Lookin' good 8) I really like where this is going :mrgreen:
Re: The "Algonquin"
Postby Lugisland on Sun Apr 03, 2011 6:56 pm
I fabricated the headtube and dropout gussets today. I haven't figured out how I'm going to tie the seat tube together with the seatstays yet. Tom
Lugisland
Re: The "Algonquin"
Postby the_canuck on Mon Apr 04, 2011 11:52 am
lovin the way those brown fat franks are going beside the patina red!
cant wait to see more...
the_canuck
Re: The "Algonquin"
Postby Lugisland on Mon Apr 11, 2011 9:56 pm
I decided that I didn't like the way the headtube gusset looked so I made another one that I like much better. The seat tube and stays are held together with a plate and gusset. I sandblasted everything and had it welded up today. The welds look good except for a few spots where it popped from some specs of Aluminum oxide (from sandblasting). I'll do some grinding and a little cleanup with bondo before primer and paint. I added the sprocket to the rear wheel after a little redneck machining to make the hole bigger to fit over the coaster hub. I still need to center it on the rim which isn't going to be easy... These kits are a good start, but it is definitely going to be a challenge to set this bike up. I'm replacing most of the hardware on the motor with hardened allen head bolts, and I need to buy an offset intake so I can get an air cleaner on the carb. I'm going to hold off on the paint until I first get it all mocked up and running. Here are some more pictures of my progress. :D Tom
Lugisland
Re: The "Algonquin"
Postby Tailwinds on Thu Apr 14, 2011 9:24 pm
That's bad A**! More more!!!
Tailwinds
Re: The "Algonquin"
Postby TheFlyingDingo on Thu Apr 14, 2011 9:47 pm
You shoulda put a little hook on it so it was a bottle opener.
Buy Bikes
TheFlyingDingo
Re: The "Algonquin"
Postby Lugisland on Sat Apr 23, 2011 7:09 pm
Okay, I've spent a lot of time staring at this thing. First of all, I'm making a color change. The motor will be Chrysler HEMI Orange with black satin covers, and the frame is getting clear coat. I've fallen in love with the raw frame. The exhaust is painted VHT header white with an orange guard. I had to punch some holes somewhere! I couldn't resist! I'm going to have motor chain line issues trying to get around these fat franks. I've still got a little room near the rear chainstay, so I need to add another "rag/rubber spacer" behind the drive sprocket on the rear wheel. Hopefully I won't need to move the motor over to match up. I've replaced most of the screws with allen bolts, and I'm starting to paint the motor. I'm going to clean up the surface where the head and jug meet because these motors are notorious for blowing head gaskets. I'll be looking for a seat, grips and some other parts next week at the Ann Arbor bike show. Here are some pictures. Tom
Lugisland
Re: The "Algonquin"
Postby FOUND OBJECTS on Sat Apr 23, 2011 7:20 pm
SWEET!
FOUND OBJECTS
Re: The "Algonquin"
Postby Cooon on Sun Apr 24, 2011 11:01 pm
Nice work, and thats such a vool shaped frame.
Cooon
Re: The "Algonquin"
Postby Fireproof on Mon Apr 25, 2011 12:52 am
Lugisland wrote: The exhaust is painted VHT header white with an orange guard. I had to punch some holes somewhere! I couldn't resist!
Lookin' real good Tom! I'm glad yer putting those knockout punches to good use and I'm looking forward to seeing what you do next. 8)
My Intro <((><
Matt 13:36-43
Fireproof
Re: The "Algonquin"
Postby wolfy on Mon Apr 25, 2011 1:18 am
Nice! love the raw frame look and the goldtone sprocket hardware.
still trying to learn to ride a bicycle using a vintage mtb.
wolfy
Re: The "Algonquin"
Postby TheFlyingDingo on Mon Apr 25, 2011 9:07 am
I should paint the block on the dynasty that orange.
Buy Bikes
TheFlyingDingo
Re: The "Algonquin"
Postby Lugisland on Mon Apr 25, 2011 9:45 pm
:D
Lugisland
