RRBBO - Good Vibrations
53 posts • Page 1 of 4 • 1, 2, 3, 4
Postby Rat Rod on Mon Jan 15, 2007 9:55 am
Here's my entry...an 80s model Huffy Good Vibrations Cruiser. We'll see just how cheap and ratty it can be done. 8)
Postby Rat Rod on Mon Jan 15, 2007 8:55 pm
Sticking with the trend of low-budget 80s model department store bikes :shock: ...I found a donor bike today for $14.99 at my local resale shop.
Will be creating a 5 speed rat...possibly with hand brakes. Parts should work fine with the Huffy cruiser frame above.
Postby Rat Rod on Fri Jan 19, 2007 11:22 pm
Recieved my tires today from Debbie at http://www.bikeworldusa.com and decided to do a little mocking up. Waiting on a set of extra long handlebars from Dumpster Diver. Still not sure what I will do for a seat. This bad boy is ratty. 8)
Postby Rat Rod on Sun Jan 21, 2007 7:03 pm
The temps finally got out of the 30s and into the 50s today so I was able to give the frame, forks and chainguard a quick sanding and then 3 or 4 coats of the old flat black. It was a quick sanding job so some of the battle scars are still visible. The best part about painting a bike flat black is that you can pick up the frame about 5 minutes after you spray it.
A couple of pics after the sanding...
Here's the frame all nice and painted. Take note of my "PARK" bicycle stand. :mrgreen:
Postby Rat Rod on Tue Jan 23, 2007 11:46 am
Well, the flat black is all dry and now I'm just playing around to see how it will look. Plan to do some custom work on the speedo and the chaingaurd. So far I'm pretty pleased with how she's turning out.
Postby Hooch on Tue Jan 23, 2007 2:00 pm
thats lookin schweeeeet!!!!
must be fast too with that major burn out under it! lol
PEDDLIN KUSTOMS FACEBOOK
MY INTRO THREAD/PROFILE
Hooch
Postby RatRodDad on Tue Jan 23, 2007 5:59 pm
It's looking good.
For a minute there I thought that was a tachometer setting on the handlebars, so it's a good thing you mentioned it was a speedometer.
I was expecting to see some white shoe polish on it with your entry number and bracket time - followed by clouds of smoke from the burn out!!
RatRod's Dad
RatRodDad
Postby Hooch on Tue Jan 23, 2007 8:07 pm
are you retaining the 5 spead?
Hooch
Postby Rat Rod on Tue Jan 23, 2007 8:41 pm
Hooch wrote:are you retaining the 5 spead?
I'm going to give it a shot. Still not sure what I will do about a shifter or the placment of it. I plan to mount a single hand brake to the rear wheel. I want to be able to ride thing more than 50 yards without running out of breath. :lol:
Postby Clothespin n on Tue Jan 23, 2007 11:28 pm
Man I love those Tires..I can't say it enough!!!!!
Pin-it !
Clothespin n
Postby Rat Rod on Sat Jan 27, 2007 2:08 pm
Added an Nirve seat...waiting for my chainring to arrive.
Postby Markm on Sat Jan 27, 2007 3:38 pm
Thats lookin REAL COOL ,RATROD!!!!!!!Love that seat!!
Postby cman on Sun Jan 28, 2007 1:48 am
It is coming along well. I only wish it was warm enough for me to paint.
Postby Rat Rod on Sat Feb 03, 2007 8:23 pm
Well, here's the latest update. I received a Schwinn shifter, chain ring and some handlebars this week for my bike. Today I was able to pack the bearings and install the crank and chain ring. One thing I ran into is that the chain that I was using from the my Murray parts bike is too narrow to fit on the Schwinn chain ring. Not sure if I will be able to use this chain ring after all. Maybe someone knows what size I need.
I also installed the new handlebars, grips and an old Weinmann brake lever. I'm still having issues with the headset on this bike. For whatever reason when I tighten down too much on it, the whole assembly is too tight and doesn't turn easily. Either I've forgoten a part or I put something together wrong. The other downer to this is that my Schwin 5 speed shifter ends up being loose because I can't tighten the headset down enought. Looks like I'll be pulling at a part in the future to see what's going on.
Oh, and I also threw on a set of Electra pinstripe decals since I don't have $100 to spend on a real stripe job. :roll:
So far just coasting around on it in my driveway has been fun..LOL!
Postby Hooch on Sat Feb 03, 2007 8:26 pm
thats lloking sweet man yea the 5speed chan is 3/32 wide and the normal chain is 1/8 so you might have to go with a bmx 3/32 sprocket or someone else might have another idea
Hooch
