can't afford moon discs Soooo.....
67 posts • Page 4 of 5 • 1, 2, 3, 4, 5
Re: can't afford moon discs Soooo.....
Postby spectratone on Fri Apr 01, 2011 11:14 pm
Just a warning... cymbals are really heavy; enough so to turn your Wheel into a Flywheel.
They are somewhat brittle, which is why they're prone to cracking.
Around the hole in the center is a common place place for cracks
or chipping to occur, so inspect that area carefully if buying used cymbals.
You would definitely want a tight fitting bushing in the hole.
Not a drummer, but I've been in bands for most of my life; seen plenty of broken cymbals :roll:
spectratone
Postby mikesbikes36 on Fri Apr 01, 2011 11:25 pm
Not a drummer, but I was in the band (not *a* band, the band) youthgeye ....the band as in levon helm ?
mikesbikes36
Postby herr_rudolf on Sat Apr 02, 2011 12:26 am
miloziffel wrote:How about some of these
Code: Select all
http://cgi.ebay.com/NSF-Aluminum-LID-ONLY-Commercial-100QT-Stock-Pot-/370327764873?pt=Cookware&hash=item5639413f89
http://cgi.ebay.com/NSF-Aluminum-LID-ON ... 5639413f89
You mean these, right?
8) Kinda looks like the real thing...
but with handles.
Postby KUZTOM BIKES on Sat Apr 02, 2011 2:13 am
cool .all ours over here are cheap plastic.... :cry:
KUZTOM BIKES
Postby FOUND OBJECTS on Sat Apr 02, 2011 9:32 am
Code: Select all
but with handles.
Looks like a 21.5" diamiter...what's a 26" rim fit?
FOUND OBJECTS
Postby FOUND OBJECTS on Sat Apr 02, 2011 9:42 am
here's what I found... The typical 26-inch rim has a diameter of 559 mm (22.0") and an outside tire diameter of about 26.2" (665 mm)
FOUND OBJECTS
Postby X-RAY on Sat Apr 02, 2011 9:52 am
i like the saucer sled idea, you could spray it with industrial strength kitchen lubricant my company is developing.... :mrgreen:
RatRodBikes---We're bad, we're nationwide!
X-RAY
Postby altoonist on Sun Apr 03, 2011 8:32 am
That's how I do it for less than $10:
Imagehttp://syracusebicycleworks.blogspot.com/2011/04/9th-meeting-of-cbc.html
altoonist
Postby EasyRider420 on Sun Apr 03, 2011 12:33 pm
This is by far one of the coolest "rat" additions I've seen in a while!!
Rat on and Rat Hard.
EasyRider420
Postby FOUND OBJECTS on Sun Apr 03, 2011 2:18 pm
I wonder how a pizza pan would work... :?:
FOUND OBJECTS
Postby Kevin B on Sun Apr 03, 2011 4:04 pm
The trash can lids are a great idea! Really inovative thinking.
Kevin B
Postby KoolKat on Wed Apr 06, 2011 9:38 am
Very creative and cool. Well done! 8)
“A pessimist sees the difficulty in every opportunity; an optimist sees the opportunity in every difficulty.” Winston Churchill
KoolKat
Postby DUSTER666 on Thu Apr 07, 2011 6:14 pm
Yeah these are cool might have to give them a try, just for the heck of it..... :mrgreen:
NO I will not buy your Schwinn Sting-Ray for $5,000.00
DUSTER666
Postby chiselhead1133 on Mon Apr 11, 2011 10:39 am
when i was in hi-school, worked at pizza place put deep dish flat black pans on my friends rad-ilac. good idea keep it up
chiselhead1133
Postby GreatWhite00 on Mon Apr 11, 2011 11:10 pm
mikesbikes36 wrote:Not a drummer, but I was in the band (not *a* band, the band) youthgeye ....the band as in levon helm ?
Lol, Mike. I was wondering the same thing myself.
I like bikes.
GreatWhite00
Users browsing this forum: loudboys and 10 guests
