Monark Board Track Racer
56 posts • Page 1 of 4 • 1, 2, 3, 4
Postby RestoRodSchwinn on Sat Feb 26, 2011 6:24 pm
This is my fourth build in the last four years and my first since becoming a member here. It's the first that I will document. Also, it's the first where the finished product isn't going to really resemble what I started with. It's very possible that the only thing I use from the donor bike is frame - maybe the front sprocket, too. The plan is to do it in the style of a board track racer with flipped bars and a leather seat that sits low and back a bit.
I change my mind a lot, but right now, I'm looking to have the frame and monarch springer powder coated in a medium gray, and the S-2 rims I'll be using in a dark blood red with off-white or gray pinstripes on either side of the spokes. Before the frame goes to the powdercoater, I'm going to stop by my dad's place and weld up the holes in the frame that won't be used - fender mount holes in the rear dropouts, etc., and a hole in the right seatstay that was for ?? I've been told it's a mid-50's middleweight, but 2.125 tires fit with plenty of room to spare.
One thing I'm missing is a tank. I've seen Monarch Rockets with tanks that look like they'll fit my frame. If any of you have one of those or another tank that will fit sitting around, I'd love to buy it. :D
Here's the donor bike-
Someone beat the crap out of this thing. You may be able to see that the forks are bent. And, upon pulling the cranks, I discovered that they were tweaked by around 10 degrees.
Please, be my friend - Facebook
Like my Resto-Custom Page - True Garage
Schwinn Junkie
RestoRodSchwinn
Re: Monark Board Track Racer
Postby RestoRodSchwinn on Sat Feb 26, 2011 7:13 pm
Alright, gotta get this thread caught up to the current state of things. First, I've stripped the bike down to the frame, and disassembled the wheels I'm going to use - S-2s with a Schwinn script hub in the front and a New Departure coaster in the rear.
Frame and hoops ready for blasting and powder coat (just waiting for the Monark springer to join them)-
And, a collection of parts I'm getting together to be re-chromed. The hub bodies and the Monark sprocket are for this build-
The next step in this build is to sell some of that stuff in my garage and raise some funds!! :D
Schwinn Junkie
RestoRodSchwinn
Postby Skipton on Sun Feb 27, 2011 2:41 am
Great start! looking forward to this one!
Postby RestoRodSchwinn on Sun Feb 27, 2011 11:00 am
I'm pretty excited myself! Thanks for your insights and encouragement in the board track racer thread :D
Schwinn Junkie
RestoRodSchwinn
Postby Strings_and_steam on Sun Feb 27, 2011 12:45 pm
I dig those frames, and the sprocket is really cool! I'll be keeping an eye on this one :mrgreen: I really like the boardtracker asthetic and history, I'm excited to see what you do with this :D
S&S
Strings_and_steam
Postby Skipton on Mon Feb 28, 2011 12:31 am
RestoRodSchwinn wrote:I'm pretty excited myself! Thanks for your insights and encouragement in the board track racer thread :D
You are welcome! I do love a Cool Monark!
I take it you ordered a Beefed Up Monark Springer?
Going to be a cool bike 8)
Strings_and_steam wrote:I dig those frames, and the sprocket is really cool! I'll be keeping an eye on this one :mrgreen: I really like the boardtracker asthetic and history, I'm excited to see what you do with this :D
Could not of said it any better. :D
Postby RestoRodSchwinn on Tue Mar 01, 2011 9:29 am
Skipton wrote:I take it you ordered a Beefed Up Monark Springer?
Unfortunately, I ordered mine before I knew about the beefed up ones. But, as luck would have it, my dad's a great welder and fabricator, so we're going to do our own beefing.
Schwinn Junkie
RestoRodSchwinn
Postby RestoRodSchwinn on Sat Mar 12, 2011 4:23 pm
Alright. I'm heavily leaning toward making this a motorized bike with the Grubee Skyhawk GT5 Super Rat setup. If I do, I'm guessing the wise thing to do would be to fit the engine, etc., fabricate a tank of some sort, then disassemble it and get the powder coating/chrome plating done. This will be my first build of this type - any quick advice would be appreciated.
Schwinn Junkie
RestoRodSchwinn
Postby dash on Sat Mar 12, 2011 10:32 pm
RestoRodSchwinn wrote:Alright. I'm heavily leaning toward making this a motorized bike with the Grubee Skyhawk GT5 Super Rat setup. If I do, I'm guessing the wise thing to do would be to fit the engine, etc., fabricate a tank of some sort, then disassemble it and get the powder coating/chrome plating done. This will be my first build of this type - any quick advice would be appreciated.
don't use the chain tensioner that comes with the kit,use a half link on the pedal side to suck up some slack, make your own motor mounts and weld them to the frame, buy a hub adaptor to mount the sprocket from pirate cycles the one that comes with the kit will fail! locktight all screws, and most important buy a better throttle !
http://www.Jonsbigbikes.com
dash
Postby RestoRodSchwinn on Sat Mar 12, 2011 10:58 pm
dash wrote:use a half link on the pedal side to suck up some slack
Not sure that I understand this exactly, but I'm all for ditching that clumsy looking tensioner.
dash wrote:buy a better throttle !
Any suggestions where I could find one of these?
Thanks!
Schwinn Junkie
RestoRodSchwinn
Postby dash on Sat Mar 12, 2011 11:52 pm
http://www.piratecycles1.com/ you can get the half link and the hub adaptor from these guys. napa auto parts sells a throttle for 10 bucks its not bad also sickbikeparts sells a throttle that's good or you could go to your local motorcycle shop and get one if you realy want to do your home work go here http://motorbicycling.com/
dash
Postby RestoRodSchwinn on Sun Mar 13, 2011 12:33 am
Thanks a bunch, Dash!
Schwinn Junkie
RestoRodSchwinn
Postby dash on Sun Mar 13, 2011 1:06 am
RestoRodSchwinn wrote:Thanks a bunch, Dash!
not a problem and im looking forward to the build, your frame will make a sweet boardtracker! please keep in mind their is a reason those kits are only 200, the engine it self is OK but that chain tensioner and the throttle are a trip to the hospital waiting to happen! one last bit of advice, if you make your own tank seal it with kreem, you can get it on amazon, also invest in a inline fuel filter.
dash
Postby RestoRodSchwinn on Thu Mar 17, 2011 12:53 pm
Acquired the tires I'll be using for this build through my local bike shop. Picking them up after work!! They're Cream Felt Quick Bricks. Very excited!
Has anyone ever used a drum brake on a Monark Springer? If so, which leg (front or back) did you tie it to, and how did it work. I know I can go ahead and put a disc on it, but I like the look of the drum so much better.
Schwinn Junkie
RestoRodSchwinn
Postby RestoRodSchwinn on Wed Jun 29, 2011 9:41 am
After getting derailed by life, this project is back on track. I've enlisted my dad to build a tank, beef the frame, and build custom engine mounts. He used to make a living doing bronze sculptures. We're making a tank out of sheet bronze as well as fairings between the seat tube and the rear tire. Haven't decided whether to polish or patina the brass - maybe a combination of the two so it looks old, but cared for. I'll get some pics up as soon as we have something.
Does anyone have a particular engine kit to recommend? I should be ordering within a week or so.
Schwinn Junkie
RestoRodSchwinn
Users browsing this forum: gm54210 and 4 guests
