Tribute to our friendsRe: Tribute to our friendsNice! So far this thing is lookin awesome!
Re: Tribute to our friendsHere's a thought. Get a second Lampy or something similar - and mount it on the frame somewhere - maybe on the seat tube down under the seat.
Take the bulb out of that one and in it's place, solder some wires to the bulb connections. Then run those wires under the fender to the original Lampy - and pull the back end off of that one and remove the batteries and solder the wires to the back of that bulb connection. So that way you could keep the batteries and the off / on button on the second Lampy out on the frame - and only have the bulb in the original one. Then you could use the off / on switch on the second one to turn it off and on. And you could easily change out the batteries whenever they needed changing. That's one idea and I'm sure there are lots of other ways to "get 'er done". It will be fun to see what you finally decide to do. RatRod's Dad
So the second lamp would be the switch and batteries to the first? Seems like you'd just remote mount a power source and switch to the original tail light. ~AJ
PEDAL GRINDERS B.C.+ C.C. OF SACRAMENTO
Re: Tribute to our friendsif you can find a touch switch [like the touch desk lamp]
or maybe you can get some information for the specialist in electronics they work with diod ,sensors and micro switchis I think exist evan touch torchlight try chinese products in google maybe you will find somethink the bike it is turn verrrry good
Re: Tribute to our friendsZoso, that's pretty much what I suggested. The second light would not really be another light - but just a remote power source and switch for the original light.
I just thought it might be easier to make it up from another light than to come up with a different type of power source and switch. Fireproof and his daughter will probably come up with something even more creative. RatRod's Dad
This is why I've not made any suggestions. I couldn't come up with anything better than what they are doing.
Re: Tribute to our friendsJust read from page 1. Awesome, awesome build!! Can't wait to see what's next.
Re: Tribute to our friendsThanks to all for checking in and for your nice complements. My daughter wanted to give an update tonight, but as she was finishing her homework, little bro informed us that he needed a report typed for tomorrow. While I typed, those two fell asleep, so I’m doing the
update. We like your idea RatRodDad. The flashlights we are using have sealed switches and the batteries are held in a removable cartridge. Be a shame to waste good stuff like that! We did a little experiment with the flashlight and found that your idea will work great, but I also found out that we can solder one wire to the bulb (actually, it’s a printed circuit board with the LEDs on it) and the other end of the wire to the battery cartridge. Since the bulb holder is held to the fender with two set screws, it will be grounded. All we need to do is ground the “switch/battery holder” when we mount it and the circuit will be complete using only the one wire. Thanks for your help! Don’t wait! Time flies, so get them involved with what ever you are working on (or better yet, get them their own projects that you can work on together), but do it as soon as you can. If they’re too young to do the actual work, teach the names of tools/equipment, safety habits, etc. Have some old clothes for them to wear for when they help dad. Buy them some gloves and goggles that fit. Let them have fun while they learn some cool stuff. "Train children to live the right way, and when they are old, they will not stray from it".
Blinky's new disguise
Thanks for backin’ me up Druggedonions, but I would have felt bad takin’ my son’s clamps. Gotta side with Nick-ish on this, so we will be doing something a little different here. Again, wanting to utilize the sealed switch and removable battery cartridge that these flashlights have, I thought it would be nice to have "Blinky" hidden in plain sight! Hope you like this little game of Hide-N-Seek as we do our best to camouflage this thing! This is some of the stuff we'll use . . . those circles are MDF (that’s a fancy way of saying sawdust mashed into the shape of a board! I’ll be using a couple short pieces of that white rod . . . it’s 3/4" diameter fiberglass. Those four little pieces in the lower left were cut from that dark brown sheet of .062" phenolic. A few more things . . . styrene, the black is .062", and the white is .25" thick; acrylic, the blue stuff is actually .090" clear with blue masking, and the other is .25" mirrored; on the right is 3/16" aluminum. ![]()
Re: Tribute to our friendsHi! I've been following your build with great interest, usually with my mouth hanging open in awe. With your combined skills, proper equipment and very innovative ideas you bring customizing to another level.
I'm an electrician by trade and have spent many years doing residential service work. The biggest enemy of mechanical electrical connections is corrosion. Even if the materials are identical the connections are a resting place for condensation from humidity. I adapted this little trick from copper/aluminum connections in which you use an anti-oxidant to prevent the natural oxidation of the two different materials. It usually comes in small tubes or squeeze bottles and can be purchased anywhere a full range of electrical supplies are sold - i.e. Lowes. Back in the old days it was a lot more common for vehicle owners to remove and replace their own batteries. Inevitably the battery clamps would have corrosion on them and would need to be cleaned. Many a car owner lost power to their starter because of the corrosion that could form on the interior of the clamp and exterior of the battery pole. I found if after cleaning all electrical contacts you coat the cleaned surfaces as well as the outside of the clamp with the anti-oxidant no corrosion will ever form. It does not dry up even after years of exposure to the elements and it conducts electricity so as to aid contact when using jumper cables. My only recommendation is when you install the light unit with set screws that you coat all the surfaces where contact is needed such as where the set screws tighten against the mounting material as well as the actual threads of the set screws themselves. This simple step will maintain your electrical connections for years to come. A small tube costs practically nothing and you two don't seem the type to skip over something lightly. You won't regret it and keep up the fantastic work. Thanks. Robert
Re: Tribute to our friendscant work out what your going to do with all that stuff but i'm exited to see!
"pain is temporary but quitting is forever"
cheers nick
Re: Tribute to our friendsThis thread is becoming the bright spot in my day. With so much horrendous stuff going on in the world, it is a welcome relief to come here and check the latest installation in this coolest of all possible projects. Fireproof, you and your daughter are doing more good than you know. Keep it up!
JWM So Cal Rat Rod Ride.
Every second Saturday of the month Corner of Brookhurst, and Atlanta Huntington Beach, CA
Re: Tribute to our friendsThanks to everyone for all the compliments! And also, Road Master, thanks for the helpful tip about the anti corrosion grease! We hadn’t thought of that and it would not be a good thing to overlook on my bike.
So here is what my dad did with all those seemingly random materials. After the glue dried on the MDF disks (those sawdust things), my dad put them into the lathe and shaped them. After the lathe, he drilled a 3/4" diameter hole through the side and inserted a couple of short pieces of the fiberglass rod. Than he cut some 1/16" inch wide slits and inserted the tabs of phenolic. Here it is sanded smooth and ready for the next step . . . thermoforming. ![]() Here is your classic Heartland manufacturing thermoforming machine from the mid 1970's. ![]() Here are the parts that were made on the thermoforming machine. The first step after taking them out of the machine is a rough trim on the bandsaw. You can see the part on the right ![]() This is the other piece being trimmed in the lathe. ![]() Here are some of the parts my dad made to finish the basic headlight. The black and white discs are 0.62" styrene. The smaller white discs are 0.25" styrene. Notice that my dad has pressed one of the brass inserts into one of them already. The reflector (top left) is made from 1/4" acrylic mirror. ![]() This is a view inside with the disks glued in place. They reinforce the headlight bucket. The white things with brass inserts are how we will mount it onto the frame plus a bracket. ![]()
Re: Tribute to our friendsi bet if we gave you two a box of eggs you could build the Effiel tower nice job on the light cant wait so see it mounted and working! "pain is temporary but quitting is forever"
cheers nick
Who is onlineUsers browsing this forum: No registered users and 7 guests |
