1947 Dayton
35 posts • Page 1 of 3 • 1, 2, 3
1947 Dayton
Postby someguy83 on Sun Jan 30, 2011 4:58 pm
I picked up this frame at a motorcycle swap meet this past summer. I thought it looked like my Hiawatha, which I wanted to alter, but everyone was telling me to leave the Hiawatha the way it was.So here is my chance to build what I want and how I want.
The frame looks solid but covered in red house paint applied with a brush uggh :? Oh well, good thing I work as a spray technician and am able to lay down some flat black once its stripped. :lol:
The fork was broke when I bought it. The break looked pretty clean and a welder buddy of mine fixed it up for me. Before:
Close up of the break together:
After my buddy welded it together and I sand blasted it at work:
Heres a shot of the front fender after some straightening and sandblasting:
Heres the mounting hole where the screw goes through into the bridge of the fork (it will need a little work :roll: ):
My intro:
viewtopic.php?f=9&t=30637&p=299962#p299962
My build:
viewtopic.php?t=36020#p352337
someguy83
Re: 1947 Dayton
Postby someguy83 on Sun Jan 30, 2011 5:42 pm
Heres a shot of the sweet heart skiptooth:
The sprocket is bent and hits the frame but I think I can flatten it back out with some friendly persuasion :D
And while we're looking at the bottom portion of the bike, here's the serial number:
And the drop outs:
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby someguy83 on Sun Jan 30, 2011 6:03 pm
Well I figured I would have some work ahead of me and there were several parts that I would need before I could have this thing rolling. I figured I might want something to sit on so I put the task before you all to find a seat for me and udall came to my rescue he sent me this one here:
And here is the bottom side:
And here it is after being torn apart stripped sand blasted and primed:
The seat did not have the mounting bracket so I was able to contact battenkustoms and he hooked me up with the seat post and brackets here:
(This is after sandblasting the rust off of it and priming with Rustoleum)
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby SCHWINNRAY69 on Sun Jan 30, 2011 6:28 pm
Great start :P
Re: 1947 Dayton
Postby 37fleetwood on Mon Jan 31, 2011 7:33 pm
looking good, just wanted to post so I could follow your build easier.
the sprocket is the Colson style, still very cool looking. glad you saved the fork the Huffman forks aren't easy to find.
President Southern California Huffman Rescue
Thanks
Scott 8)
37fleetwood
Re: 1947 Dayton
Postby someguy83 on Wed Feb 02, 2011 8:23 am
....the hip bones connected to the leg bone, the leg bones connected to the foot bone, the foot bones connected to the...... uh oh I don't have any pedals!!!! Oh well back to the site to see what I can find :lol:
Oggy had these sittin around and they were the right diameter for my crank arms:
The bearings were nice and free so no work to be done here except to bolt them on!
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby someguy83 on Wed Feb 02, 2011 8:48 am
Lets see I've got the frame, I have a place to sit and pedals to transfer leg power to the rear wheel. Which brings me to my next thought for this bike- The last time I owned a bike it was a 21 speed mtb. You get a little spoiled with all those gearing combinations and I decided I wanted something more than single speed. Udall had a slightly unusual rear hub that came off the ORIENT EXPRESS bike build available and unusual/ratty is the whole theme for this bike.
Since this is the first time building I totally overlooked the concept of different numbers of holes in hubs. I thought I could swap out the old hub for the new but then realized that the new was 40 hole and the old rim is 36. Gee that won't work now will it? So I had to then buy the old rim from the ORIENT EXPRESS and relace the hub. (Forty hole hubs are NOT easy to find, nor are they cheap)
Well this now leaves me with a decent 36 hole coaster brake rim and hub, hmm I could sell it to get more money for the bike. Wait a minute I need a front wheel or I won't be going anywhere! Well lets just see if I can set up a suicide front brake using the coaster brake hub and wheel! Stay tuned this will either be really cool or a miserable failure!
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby OUTLAW on Thu Feb 03, 2011 5:46 pm
i am putting a freewheel and coaster brake system on my Burrito. there is a post out there about another one that was done. i have it in my post about my Burrito if you want to look for it or the other post. maybe someone will know where that post is and put it here for you. the project looks good so far. have fun.
Outlaw
Outlaw Bikes
BURRITO'S RULE
OUTLAW
Re: 1947 Dayton
Postby someguy83 on Fri Feb 11, 2011 1:43 pm
Well its that time of the year when its cold and tax season is upon us and I don't have any work to do, so I get a day off :? That means.... catch up on some stuff I have wanted to do for a while, including finish stripping the frame...... Will post pictures of progress soon but for now here's what we got....
I sprayed the crank and the head tube bearing cups with some simple green degreaser to clean them up a bit and hopefully loosen any dirt that may want to fight the process of removing the crank. more to come soon after lunch.....
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby someguy83 on Fri Feb 11, 2011 6:14 pm
Alright I got back out to the garage and found that my plan worked the degreaser loosened the crud on the parts and everything came apart nicely. Took the fender and the kickstand off....
Took off the crank and sprocket....
My biggest fear when pulling the crank apart was that I would find a bunch of loose bearings and/or lose one, but I was happy to find that they were captive bearings and of course coated in sludge....
Those went into the bucket of degreaser with other parts to soak.....
After soaking awhile(maybe an hour) and a little scrubbin with a brush, I think they cleaned up well...
(Does anybody know if these are or could be the original bearings?)
Cleaned up the crank arms a little and found a casting mark on the mid section, it says SMB......
(Anybody that knows what this means or if it has any meaning, let me know)(Not that it really matters but odd random facts always intrique me :lol: )
Well thats all for now....
Next time the frame will be stripped of that ugly house paint :)
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby 37fleetwood on Fri Feb 11, 2011 9:16 pm
the sprocket and crank are definitely not the originals but who knows the bearings may be, National was one of the big providers of the time, they may also have come with the Colson crank and sprocket. the Huffman crank would have been originally marked with Huffmans mark.
Thanks
Scott 8)
37fleetwood
Re: 1947 Dayton
Postby someguy83 on Sat Feb 12, 2011 3:43 pm
I have been stripping the paint off the frame today and may have found something a bit unusual.......
I have sent a PM to 37Fleetwood to possibly get down to the bottom of it.....
Might be wishful thinking but might be something VERY COOL.....
I know right now I am teasing all who may read this but I want to keep my hopes in check for a bit. So as soon as I find out from fleetwood I will reveal what may be a great find. Fleetwood if you read trhis and have not checked your messages then pls do so I apologize again it is a lengthy message!
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby someguy83 on Sat Feb 12, 2011 9:10 pm
Well the frame is NAKED :oops: ....
Here is what I found while stripping the paint today... I was using a wire wheel chucked into my electric drill, that I clamped into my work table (kinda made a redneck bench grinder/wire wheel, but it works) and the house paint was coming off really easy. I was not using much force against the wheel so I figured it would just sluff off the house paint and reveal the factory color. But in fact as it was coming off it was revealing clean shiny metal! Random thoughts were flying through my head at this point....
1 Did somebody strip the frame before me and then BRUSH ugly red paint on it? Well that wouldn't make much sense to me but who knows?
2 Was this a frame that was originally in chrome?????? So I sent fleetwood a message to which he answered that he did not know of any factory chromed frames and also pointed out that if it were chromed from the factory then the joints would not be brass colored but chromed as well. So although it would have been sweet to find a chrome frame I am sad to say that NO it is NOT.
So it is my guess that at some point the frame was stripped and then repainted but done horribly. But on the bright side, that miserable looking paint job had in fact preserved a great looking frame. Now this discovery leads me to a new decision to make. I originally had planned on shooting it a flat black, but the new thought is..........maybe I could polish it up a bit and then clear coat it. The fork and fenders are not good candidates for cleaning and polishing by any means so I would still be spraying those some color. I already have the flat black.
What do you guys think? 1 All flat black OR 2 Polished up frame with flat black fork and fenders? And either color scheme will eventually include some striping on the fenders in most likely red and white and/or yellow. Let me know what y'all think.
My intro:
My build:
someguy83
Re: 1947 Dayton
Postby OUTLAW on Sat Feb 12, 2011 9:18 pm
lets see. if this were my bike i would polish it up and clear coat it after you put on some nice pit striping on the frame. with the flat black on forks and fenders i would think wow. maybe red brick tires too. ok, your call.
Outlaw
Outlaw Bikes
BURRITO'S RULE
OUTLAW
Re: 1947 Dayton
Postby 37fleetwood on Sat Feb 12, 2011 9:50 pm
what about painting the frame darts and pin striping it then clearing it leaving most of the frame shiny metal? I don't think I've ever seen anyone do that.
Thanks
Scott 8)
37fleetwood
Users browsing this forum: Google [Bot] and 5 guests
cron
