Tribute to our friends
338 posts • Page 3 of 23 • 1, 2, 3, 4, 5, 6 ... 23
Re: Tribute to our friends
Postby Fireproof on Fri Jan 14, 2011 11:39 pm
Here’s the update you’ve all been waiting for! I learned how to measure with a caliper and used one to check the opening between the two parts of the top bar. This was to see if both sides were even. We marked the differences and ground those particular spots down with a flapper wheel. We got the opening within about 0.030in between the sides (part of our plan).
This is how to read and properly use a caliper. This is the dial of the caliper. There are 100 lines on the dial. Each one represents 1 thousandth of an inch. It currently reads 0.053in.
The little numbers on the metal bar each represent 1/10 of an inch, or 100 thousandths. The edge of the bar is not quite to the 1, hence it reads 0.00.
This is the bar when it reads 0.50in. Then to get the final reading, you add what the dial says. If you cannot read it, it says 0.053in. Add them together and you get 0.553in.
This is how you read multiple inch measurements. On the bar, you can see a larger 5 raised above the other numbers. This tells you that it is 5.0in. Then you add this to the other two measurements, the littler numbers on the bar and the ones on the dial. They still read the same thing as previously, so 0.553in. Add that up and you get your measurement, which in this case is 5.553in! Now, if you didn't previously, you know how to read a caliper! :)
My Intro <((><
Matt 13:36-43
Fireproof
Postby slick on Sat Jan 15, 2011 11:34 am
Ok, i'm 33 and havn't used a caliper let alone know how to read it? :oops: Thanks for the lesson!
Rolling Relics---Ride Vintage!
If the tips of your shoes have numerous coats of Armor All, don't bother asking. I don't have the time for tire kickers.
"Cheatin death with every breath"---Jesse Dayton of The Road Kings rockabilly band
-Chris-
slick
Postby scrumblero on Sat Jan 15, 2011 1:50 pm
slick wrote:Ok, i'm 33 and havn't used a caliper let alone know how to read it? :oops: Thanks for the lesson!
:lol: :lol: owned...
scrumblero
Postby NBP MotorSporrts on Sat Jan 15, 2011 4:19 pm
WOW!
I am totally impressed.
I have a 14yr old daughter that I am VERY proud of. She is my lil tomboy, but now that she is in Jr High, she found girlie girls. Now she acts like one.
Any way, you must have one proud Dad! I cant wait to see the finished bike.
Devil with the torch. Angle with the Hammer!
Ideas not coupled with Action never become Bigger than the Brain cells they Occupied!
NBP MotorSporrts
Postby Fireproof on Sun Jan 16, 2011 12:42 am
Recently my dad found these locker doors in the dumpster behind his shop. We have a good use for them . . .
We ground the paint off with a flapper wheel . . .
. . .measured it so it would be the right width for its purpose . . .
. . .and cut it out.
Here we are bending it around a steering column after firing it with a torch.
This is how it fits in between the top bars(that being how it's used, obviously).
How it fits after bending the rear end(no, not its butt :roll: ).
Here it is after being welded.
After grinding down the weld.
We then cut out two more pieces from the locker door to fit in the space behind the head tube . . .
Which looked like this.
Looks like they fit, don’t they! :mrgreen:
More pictures to come, worked on it today . . .
My Intro <((><
Matt 13:36-43
Fireproof
Postby karfer67 on Sun Jan 16, 2011 1:01 am
i love the tank or um frame? very outside the box thinking
N*H*F*F*
karfer67
Postby scrumblero on Sun Jan 16, 2011 11:32 am
karfer67 wrote:i love the tank or um frame? very outside the box thinking
its the anti-tank... I love it!! :mrgreen:
scrumblero
Postby sensor on Sun Jan 16, 2011 1:48 pm
scrumblero wrote:its the anti-tank... I love it!! :mrgreen:
you literally took the words out of my mouth!
im really impressed with what you 2 are doing with this :mrgreen:
Re: Tribute to our friends: updated 1-16
Postby Fireproof on Sun Jan 16, 2011 5:45 pm
So yesterday me an my dear ol’ dad worked on my bike for a while and got A LOT done. Here, we are preparing the bike for welding. We used Mig wire to create a gap where we were going to weld so that we could weld in there without burning away too much of the edge of the insert . . . also we added various sized sockets to hold them in place and to create tension.
After tack welding the seams . . .
We then welded in the gaps between the tacks.
Close up on the weld here . . .
More pieces we cut out of the locker door . . .
Held in w/ a magnet . . .
Next we welded them in.
Then we ground down all those welds . . .
Yet another closeup on the front . . .
And last but not least, thank you everyone for all the positive comments! Really appreciate it! :) Oh and I hope you don’t mind all the photos . . . believe me, we have even more than these. :mrgreen:
My Intro <((><
Matt 13:36-43
Fireproof
Postby KOTA on Sun Jan 16, 2011 5:55 pm
The Quality of your work is outstanding......But it's YOUR imagination, that boggles MY imagination! Great build!
Postby greg66 on Sun Jan 16, 2011 8:53 pm
VERY NICE CAN'T WAIT TO SEE THIS OUT ON A 2ND SATURDAY RIDE.I'M PROUD OF YOU 2 . 8)
http://www.rothcustombikes.com
greg66
Postby slick on Sun Jan 16, 2011 9:18 pm
This frame is AWESOME!!!!!!!!! I want one! I wouldn't be surprised if a big company like Felt starts making some like this. The lines and shape of the hole flow very well. Now get back out there and finish it! No rest at all. We are all waiting to see this one!
-Chris-
slick
Postby DesignIt on Mon Jan 17, 2011 9:11 am
Wow! That idea is better than anything I would have come up with. Scrumblero nailed it: "The anti-tank". I think we're going to see more of them, and you were the one who started it. 8) Great work and very precise too! All that extra effort is worth it when you look at your perfect results. Thanks for the updates, and I'm looking forward to seeing the rest of the build.
DesignIt
Postby BrunneCustoms on Mon Jan 17, 2011 9:19 am
This is amazing! Very creative and well thought out. Great craftsmanship all around. Don't worry about being photo heavy builders like that. We can see what and how you are doing things. Don't be surprised if someone else tries what you're doing here on their own build. I know I would if I had a welder. Keep up the great work!
You can't be who you want to be unless you are willing to change who you are.
"Do what you can, with what you have, where you are." - Theodore Roosevelt
BrunneCustoms
Postby scrumblero on Mon Jan 17, 2011 10:19 am
:shock: this just gets better and better!! I'm with Brunne !! you guys may be starting the next trend!!.
scrumblero
Users browsing this forum: BarnesTO and 9 guests
