My 63 Schwinn 97cc motorized bicycle build
88 posts • Page 3 of 6 • 1, 2, 3, 4, 5, 6
Re: My 63 Schwinn 97cc motorized bicycle build
Postby cobrafreak on Thu Dec 23, 2010 6:52 am
Very nice. Good lines on that bike.
cobrafreak
Postby pepper on Thu Dec 23, 2010 1:54 pm
Dowie Soetenga wrote:Image
A red tank would really set off your bike
Regards
David
pepper
Postby dash on Sun Dec 26, 2010 12:33 am
is your sprocket mounted to a free wheel ? how did you pull that off?
http://www.Jonsbigbikes.com
dash
Postby Dowie Soetenga on Mon Dec 27, 2010 2:56 pm
dash wrote:is your sprocket mounted to a free wheel ? how did you pull that off?
The right side is pedal assist with a free wheel.
The left side is motor assist with a free wheel.
The gearing is all math. My blueprint drawing calls out the sprockets and ratios. I ended up making my jackshaft output sprocket 9T vs 10T to gear the bike just a little lower. Perfect.
The speed is now 29.4mph at 4,200 rpm.
My 63 board track build http://www.ratrodbikes.com/forum/viewtopic.php?f=21&t=32559
Dowie Soetenga
Postby diceman on Sun Jan 02, 2011 12:14 am
nice job ...yourthe only other person besides me that i have seen use that motor .
i did a jessie james chopper bike with the same engine ( sounds good ) .
Ratty Riders ( kitchener and waterloo ) http://rattyriders.webs.com/
diceman
Postby chainmaker on Sat Jan 08, 2011 10:31 am
chainmaker wrote:Nice looking bike..did you fab those rear brake bosses, or where did You get them those are sweet.
Cheers
About those rear brake bosses?????
CHEERS
Chainmaker
My Cruiser Build http://motorbicycling.com/f41/jenny-irene-so-far-20211.html
1950 Panther Project http://motorbicycling.com/f38/1950-panther-project-27693.html
1953 Schwinn http://motorbicycling.com/f41/53-schwinn-28722.html
chainmaker
Postby Dowie Soetenga on Mon Jan 10, 2011 4:21 pm
Cheers
Yes. I did make the rear brake bosses. Here is a tread I started showing how to make them.
http://www.ratrodbikes.com/forum/viewtopic.php?f=1&t=33168
Dowie Soetenga
Postby Dowie Soetenga on Wed Jan 19, 2011 8:46 am
Just put on my tank decals. Next is custom exhaust, heat shield / guard.
Dowie Soetenga
Postby cobrafreak on Fri Jan 21, 2011 10:31 pm
I like it. Can you take a picture of the right hand side of the bike please?
cobrafreak
Postby Dowie Soetenga on Mon Jan 24, 2011 4:33 pm
cobrafreak wrote:I like it. Can you take a picture of the right hand side of the bike please?
Here are some pictures of the right side of the bike.
Dowie Soetenga
Postby Dr. Tankenstein on Mon Jan 24, 2011 7:16 pm
I always seem to find something about a build that, 'if it were mine', I'd change.....There is NOTHING about this bike that I would change. Seriously, if it were to magically appear in my garage, it would look the same way in 10 years, 20 years.....
Cheers!
Postby Dowie Soetenga on Tue Jan 25, 2011 8:26 am
Thanks Dr. T! I try to keep my creations clean and simple. That's the hard part right? Of couse using 3D CAD helps me figure it all out before I cut or weld a single piece of steel.
Dr. Tankenstein wrote:I always seem to find something about a build that, 'if it were mine', I'd change.....There is NOTHING about this bike that I would change. Seriously, if it were to magically appear in my garage, it would look the same way in 10 years, 20 years.....
Cheers!
Dowie Soetenga
63 Schwinn 97cc board tracker (idler and heat shield update)
Postby Dowie Soetenga on Wed May 25, 2011 7:36 am
Over the last few weeks I finished the exhaust heat shield and primary chain idler. I noticed a huge difference in how smooth the bike transitions from a dead stop, to full clutch engagement, to top speed. Note that I now have a primary chain idler, (engine to jackshaft input) and a final drive chain idler. (Jack shaft output to rear wheel)
Dowie Soetenga
Postby Gdcast on Wed May 25, 2011 7:54 am
So that´s how heaven looks!!!
Please show us more!
Wanna see my rides? :
Gdcast
Postby skillsthebarber on Wed May 25, 2011 12:26 pm
what are these things called that the brakes are attached to? I need some of these for my build off bike? thanks
But then again, I could be totally wrong.
skillsthebarber
Return to BIKES WITH MOTORS
