thanks for posting these
TOOLS FOR BIKE BUILDERS
63 posts • Page 3 of 5 • 1, 2, 3, 4, 5
Re: TOOLS FOR BIKE BUILDERSthe tools youve made are just as nice as the bikes youve made with them!
Re: TOOLS FOR BIKE BUILDERSamazing ingenuity, vision, and execution of ideas and designs. cant wait to see more from your shop.
RatRodBikes---We're bad, we're nationwide!
Re: TOOLS FOR BIKE BUILDERSthank you sensor for your toughts but my bikes I build them before I had this tools .
I build them in my apartment with a grender a drill and a welder. my bikes are made last winter . and the tools what I show you now I build them in the last 2,3 weeks . soon I will put pictures with my new projects using my new tools, and show you how they work. kindly Valy
Re: TOOLS FOR BIKE BUILDERShello X-RAY and thank you for your nice words.
I will try to show you guys all my tools and to put pictures to give ideeas for beginners to build own tools cheap and easy
Re: TOOLS FOR BIKE BUILDERShello guys I will show you my first pipes bend with my roll bender
![]() ![]() ![]() ![]() here you can see my tool room dont give me space to bend enaugh![]() here when you bend a pipe you must to take in consideration minimum 300 mm lose pipe on the each side the distance of the midle roll and the side one![]() here is the first check on the jig![]() ![]() ![]() ![]() ![]() here you can see the part what I need to cut and haw luck the pipe inside the circle .the pipe is 53 mm x1,5mm very strong pipe stinless still. I work 130 minutes to bend this pipe Last edited by valy on Mon Sep 27, 2010 12:48 pm, edited 1 time in total.
Re: TOOLS FOR BIKE BUILDERShere it is my new band saw .I can cut rings to 1,5 mm thick very precis saw
Re: TOOLS FOR BIKE BUILDERSI'm learning so much from your pics. Thanks.
Don't you ever stop posting those.
Re: TOOLS FOR BIKE BUILDERSLast night I dont sleep good. and today I bought a drilling and milling machine
like TORK ARMS FOR ELECTRIC HUB MOTORS,DROPS OFF etc. ![]() ![]() ![]() ![]() ![]() ![]() ![]() come more tools naw i have posibility to buildem more fast
Re: TOOLS FOR BIKE BUILDERShello guys it is time to put my tools to work. I will show you haw I build my first tork arm for my bike.
I start with a peice of aluminium ![]() ![]() ![]() ![]() it is so easy to do it when you have proper tools ![]() ![]() ![]() ![]() ![]() ![]()
Re: TOOLS FOR BIKE BUILDERStools make the jobb to be easy and fun to see what you can build with them
![]() here it is the first check on the bike ![]() ![]() ![]() ![]() ![]() second check on the bike ![]() ![]() ![]() here Isandet and polish the chanel ![]() here I have my new tools to sand and polish my building parts ![]() ![]() hire I must to build some parts to fit my new sand paper brush and the polish roll. ![]() ![]() ![]()
Re: TOOLS FOR BIKE BUILDERS![]() ![]() polishing the chanel ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() and this it is the final product ![]() ![]() ![]() ![]() ![]() I hope you guys enjoy my work and you like what I do hire I will start to buildthem next week
Re: TOOLS FOR BIKE BUILDERShello guys today I have picture with pipe cut with my notcher .I build my self a home made water cooling with a mini pool pump and a shower handel
![]() ![]() ![]() ![]() ![]() the cutter will have a long life because the teeth of it never become hot an lose the power ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() and the pipe fit perfect ![]() ![]() my notcher is working perfect and I m very very happy with it maybe I will start to build some tube notchers to sell
Re: TOOLS FOR BIKE BUILDERShello guys I have more pictures with new tork arms
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I can build diferent models easy to fit in yours drops off .if you send me a picture with each side. the picture must to be cleare and in detail
Valy, would you mind giving me some basic dimension on the two main plates?? such as leght, width ??? Thanks
Re: TOOLS FOR BIKE BUILDERShello hondataeh6 it is not a fix dimension you can have any dimension what you wish .
but if you like mine plates they are 200mm x 70,5mm x 15mm and 240mm x 60mm x 12mm sorry I wos late with ansure.
Who is onlineUsers browsing this forum: No registered users and 5 guests |
