lets see those old school / custom shifters.
67 posts • Page 4 of 5 • 1, 2, 3, 4, 5
Re: lets see those old school / custom shifters.
Postby JoKeR63 on Thu Aug 12, 2010 7:33 am
From the Build -Off, Cinco's five speed shifter.
JoKeR63
Postby Philphine on Thu Aug 12, 2010 10:22 am
couple of 5 speed shifters for my bagger project
start where you are
use what you have
do what you can. arthur ashe
Philphine
Postby outskirtscustoms on Thu Sep 16, 2010 6:18 pm
Not functional yet but here we go. Just finished these tonight
Postby FredyBoi on Wed Jan 26, 2011 6:28 am
Quanah wrote:Maybe I shouldn't give up my idea for one, but what the heck, I have been wanting to use one of these WWI german trench knives with brass knuckles for a shift lever. I figure you could heat the blade down low to take the temper out of it so you could drill a hole in it, may have to use a masonry bit, with the tip ground like a metal cutting bit... I know this works on car leaf springs without heat.
This is really cool!!! a knife with a brass knuckle. nice one.
knuckles brass - "Add an extreme wallop to your punch"
FredyBoi
Postby spinman on Fri Jan 28, 2011 7:10 am
Sturmey 3 speed with 9/16" OD aluminum bar twisted w/ 8 ball knob
President, Jersey Devils B.C.
Check us out on Facebook
https://www.facebook.com/pages/Jersey-D ... 7066093710
spinman
Postby jwm on Fri Jan 28, 2011 8:55 pm
Installing the three speed on my Spoiler was a challenge. It took some assistance from some of the good folks over at the Schwinn forum, notably Wayne, and Chopperguy. With their advice, plus the donation of a pair of anti-rotation washers, I was able to get the hub fitted properly in the frame. The shifter was another problem. I wanted the suicide shift mount, but I did not want to have to weld, or drill the frame. After weeks of brainstorming, the idea finally popped into my head. I made a backing plate to fit between the chainguard and the frame, and drilled for four bolts to clamp the shifter mount in place. Materials- some 3mm aluminum plate that I suspect came from a road sign, and the steel ring that might have been a mount for a garbage disposall- I'm still not sure. The rest was hacksaw file and drill. Primitive Pete engineering, for sure, but- hey, it works.
Next project is the sissy bar. I'm stuck again, because what I want to build takes welding, and tube bending. But who knows- I may get another flash of inspiration.
JWM
So Cal Rat Rod Ride.
Huntington Beach, CA
jwm
Postby No Talent Clown on Sat Jan 29, 2011 2:38 pm
Sturmey 3speed Frankenshifter
uh, what?...
No Talent Clown
Postby MadMax '58 on Mon Jan 30, 2012 6:34 pm
MadMax '58
Postby Peatbog on Mon Jan 30, 2012 7:52 pm
ohchusan wrote:Image
:shock: :shock: Holy Moses! That thing is sweet! :shock: :shock:
Postby wimpy on Tue Jan 31, 2012 3:42 pm
Just a modified 3-speed gripshift (Shimano)
20TWENTY8EIGHT
wimpy
Postby cinger on Tue Jan 31, 2012 4:08 pm
This is from my tandem 3 gears.
OLD SCHOOL is COOL
Groeten Gert.
cinger
Postby spinman on Tue Jan 31, 2012 7:06 pm
spinman
Postby kingfish254 on Sat Apr 14, 2012 7:23 pm
This thread deserves to be percolated back up to the top.
There are some cool shifters out there.
Postby kingfish254 on Sat Apr 14, 2012 7:25 pm
This bike is sick!!!
Looks like the shifter is just like the ones that I have except it doesn't have an overload tube.
viewtopic.php?f=2&t=51464&hilit=+shifters
ohchusan wrote:here's mine.
bombshelterbikes over at freakbike nation gave this 5 sp shimano to me and i added the sparco gearknob for added bling! haha
Postby freddyfingaz on Fri Oct 26, 2012 2:45 am
I agree this forum need to bring back. I just finished made rod shifter tonight for my build. Here's pic of it.
freddyfingaz
