Mr. Goodyear-actual photos
27 posts • Page 2 of 2 • 1, 2
Re: Mr. Goodyear-actual photosI figured I better check the fit before I started unlacing the 3-speed, after all, it's from a complete working bike."DOH!"
Re: Mr. Goodyear-actual photosI like the idea of the minimalistic approach, JMO....I'm actually using a tank, fenders and a guard this build off! I'm glad Steve "added" the software for picture size, because yours are the first pics I've seen come up LIFSIZE!
Re: Mr. Goodyear-actual photosI hope my self-imposed standards don't come across as cycle snobbery or disrespect for artistic endeavors, functional or otherwise. I don't extend my requirements to other people's bikes. I like all kinds of cool stuff that I have no intention of imitating for my own use. To quote the philosopher,"I like where these builds are going!".
Re: Mr. Goodyear-actual photosjust build what you love and leave it at that. i have traditions with my builds most dont have chain guards or fenders. but then again the last two build off bikes did have chain guards but like you say about being artistic they were both deals where the parts i had were so cool not using them would have been a shame. as for getting whacked yea if you not in the "lumped" club your just not cool. actually i dont think i am in that club yet so once again i am tragically un-cool
N*H*F*F*
Re: Mr. Goodyear-actual photosSometimes things just work out. The wider old steel let the ww2.125" tire that came on the "Schwinn" fill out at the bead, just clears the drive belt, the hub/gear fit the chain(I've got room for another link)and is MUCH sturdier, brake wise especially. As for my project, the street tires have regained a normal profile on the narrower MTB rim type that they were designed for, the bike is at least 1 1/2 lbs lighter
Added spacers to front steel on donor, replacing thick locknuts w/ thin on project/alloy whl. I need to file the fork dropouts to fit full it's all about the bikes, man. viewtopic.php?f=6&t=50053
Re: Mr. Goodyear-actual photosI just noticed I hadn't posted that the fork I'm using is 24", which is why the standard wienmanns reach the wide tire rim. To put a standard tire on here, the brake would have to be removed, possibly the front tab ground out! It has very nice handling this way, I like it.
Re: Mr. Goodyear-actual photosI'm not going to call it done yet, but the things that count for me in a bike are pretty much all sewn up. The seat post, steering head, and wheels are all in plane, no whakadoodle dishing or other desperate measures required. The fork took a little minor tweaking, but the old Columbia frame is dead straight, and fairly light as well.(for a steel bike). Filing the front dropouts was a breeze, the home was already sized for 5/16, so I only had to open the entry slightly. The wheels I'm using now are much more appropriate for the the general direction of this build, the tires fit better, and they're at least 2 lbs lighter! The seat/handlebar/crank relationships are well within my narrow window of acceptance, almost perfect. Handling is pretty neutral and light, hooray
Re: Mr. Goodyear-actual photosAlso swapped the wheel bearings in from the Hystop, because 1 of the cheap cages was damaged on the new wheel, it would have gone south given a little more time.
Re: Mr. Goodyear-actual photosawesome this bike is looking hot! it looks like an actual go-er!
Re: Mr. Goodyear-actual photosLast view before completed post, I'm still contemplating some minor appearance details. Functionally, no changes. The little bag under the seat contains a stubby wheel wrench, a few glueless patches, and enough CO2 to inflate at least 1 tire all the way.
![]() it's all about the bikes, man. viewtopic.php?f=6&t=50053
Re: Mr. Goodyear-actual photosEvery paint detail idea I came up with seemed to add to the imbalance of tight chromed front, and open plain rear. I finally came up with the only logical solution. It's chrome, it's slightly ratty...
SURRENDER TO THE RACK!!! Day light pics in the finished bikes forum tomorrow it's all about the bikes, man. viewtopic.php?f=6&t=50053
Re: Mr. Goodyear-actual photosDrive chain photo restored, I'm starting to figure out this internet stuff.
