My 63 Schwinn 97cc motorized bicycle build
88 posts • Page 4 of 6 • 1, 2, 3, 4, 5, 6
Re: My 63 Schwinn 97cc motorized bicycle build
Postby Rat Rod on Wed May 25, 2011 12:33 pm
Dowie Soetenga wrote:Yes. I did make the rear brake bosses. Here is a tread I started showing how to make them.
http://www.ratrodbikes.com/forum/viewtopic.php?f=1&t=33168
Postby Dowie Soetenga on Wed May 25, 2011 12:36 pm
skillsthebarber wrote:what are these things called that the brakes are attached to? I need some of these for my build off bike? thanks
They are custom fabricated to put modern brakes on a vintage schwinn frame. Here is the construction. The split shafts clamp on the rear of the frame so you do not have to weld them to your frame.
My 63 board track build http://www.ratrodbikes.com/forum/viewtopic.php?f=21&t=32559
Dowie Soetenga
Postby Dr. Tankenstein on Wed May 25, 2011 1:49 pm
This is such a brilliant idea and one that I'm sure will be copied numerous times in the future.
Great work.
Cheers,
Postby harry76 on Wed May 25, 2011 5:59 pm
Very very nice. That brake idea is genius!!!!
harry76
Postby Dowie Soetenga on Thu May 26, 2011 8:59 am
harry76 wrote:Very very nice. That brake idea is genius!!!!
Thanks for the positive feedback(s) on the brake bosses. They work great might I add. I've been running them for one season with no issues. The split shaft collars "clamps" hold tight. I've had no issues with them shifting after I installed them. If I had the time to make a good welding jig, I'd make them in bulk.
Dowie Soetenga
Postby Dr. Tankenstein on Thu May 26, 2011 9:27 am
Where can one purchase a "split shaft collar"?
Just askin'.....for now. :mrgreen:
Cheers,
Postby Dowie Soetenga on Thu May 26, 2011 12:23 pm
Dr. Tankenstein wrote:Where can one purchase a "split shaft collar"?
Cheers,
A good Ace or True Value hardware store carries them. They have both metric and standard. The rear frame tubes on my 63 schwinn measured .551" so a 14mm split shaft collar fits perfect. I used split shaft collars for my motor mounts as well. 1.00" for the bottom two mounts, and .625" for the top mount. They work great. You can order them online though http://www.mcmastercarr.com . Just type in shaft collar, and navigate to two piece clamp on version.
Dowie Soetenga
Postby Dr. Tankenstein on Thu May 26, 2011 2:04 pm
Thanks brother!
Cheers,
Postby harry76 on Thu May 26, 2011 3:03 pm
These split collar thingys are very useful..... ive seen these used to make replica 2 piece boartrack handlebars
harry76
Postby rydr1 on Thu May 26, 2011 6:58 pm
Amazing work.
rydr1
Postby lmpromo on Fri Jun 10, 2011 4:35 am
Hi Dowie
We are all little kids when we see a build like this that we can all see ourselves enjoying the
dream of getting on this awesome bike and riding it ourselve. Thank you for sharing the pictures and that only proves that anything is possible as long as we believe it could be built and the genious it takes to actually achieve it.
lmpromo11
Harvey
lmpromo
Postby bhaltima08 on Fri Jun 10, 2011 4:42 am
Wow, all the great fab work and detailed cad images. You could make some serious coin if you took orders for some of your fab'd stuff. I love the rear break mounts, but unfortunately don't have the equipment to make them.
:D
bhaltima08
Postby chagovatoloco on Fri Jun 10, 2011 9:57 am
Ok off topic, but is that a flat head I see in the back round? nice :D like they say hot rods don't have valve covers :lol:
chagovatoloco
Postby phusion x on Mon Jun 13, 2011 1:45 am
what cad program(s) did you use to do that model. id love to be able to do something other than blueprints. thanks.
Im old enough to remember when we were young, we sold our bikes for LESS than what we paid for them new.....stores should start selling used bikes.
phusion x
Location: North of Detroit motor city - welcome to the jungle
Postby Dowie Soetenga on Mon Jun 13, 2011 7:46 am
phusion x wrote:what cad program(s) did you use to do that model. id love to be able to do something other than blueprints. thanks.
Thanks for the positive feedback guys. Keeping the design simple is the hard part. I used an engineering program called SolidWorks to to the 3D CAD modeling, renderings, and blueprints.
The hot rod in the background is a 1931 Ford Roadster with a 1939 Flathead V8 motor. My board track bicycle has a 2.5HP flathead as well. Flatheads forever!
Dowie Soetenga
Return to BIKES WITH MOTORS
