For all kinds of forks.
What are the ways to get old bicycle forks to except the newer bigger axles?
Old Fork To Bigger Axle
9 posts • Page 1 of 1
Old Fork To Bigger AxleFor all kinds of forks.
What are the ways to get old bicycle forks to except the newer bigger axles? ![]()
Re: Old Fork To Bigger AxleI file the forks a little on both sides.
That. Some form of filing or grinding to widen the slot. Do it carefully and evenly to make sure that the axle alignment is retained.
Re: Old Fork To Bigger AxleOr file the axle but i prefer filing the forks instead.
Re: Old Fork To Bigger AxleAxels are easier to replace if something happens.
Re: Old Fork To Bigger AxleFiling the axle creates a stress riser that could lead to a failure. Opening the fork up, not so much. Granted, it will probably not likely be an issue, but I wouldn't do it just on principle. There probably is a reason that the industry moved to a larger standard size. That, and I'd imagine a front axle failure could be, um, eventful...
Re: Old Fork To Bigger AxleNot sure at all, but, Ive worked with a lot of different kinds of steel through the years and the new, bigger dia. axles dont seen to be as good a steel as the old ones. My guess (and guess it is) is that the lower quality, but bigger dia. probably about equals the older, small dia. 'better' steel. Im inclined to open up the dropouts if needed.
Re: Old Fork To Bigger AxleOk because part of the reason I wanted to know is that Spaceliner Klunker I have, whoever owned the bike did it when he turned it into a Klunker.
Ditto. it's all about the bikes, man. viewtopic.php?f=6&t=50053
Who is onlineUsers browsing this forum: The_Black_Monark and 3 guests |
