TOOLS FOR BIKE BUILDERS
63 posts • Page 4 of 5 • 1, 2, 3, 4, 5
Re: TOOLS FOR BIKE BUILDERSdo you think that pump would work for a parts washer?
RatRodBikes---We're bad, we're nationwide!
what about the cutter shaft, can you post more picture on it?? Thanks
Re: TOOLS FOR BIKE BUILDERShello guys
X-RAY do you talk aboute my mini pool pump what I use for water cooling I use the pump for the notcher and for drillind and milling machine sorry but I dont understund what is a parts washer I m very bad in english you can translate for me in pictures or drawing please.
Re: TOOLS FOR BIKE BUILDERShello honda you can go back to the pictures I have some there but if you want some details tell me what you want and I will took some pictures for you with wich details you wish to see
some guys want to know what I use for polish aluminiun or steinless steel here I have some tools what I use now for the moment when I will have a garage I will build one automatic for polishing pipes in one go. ![]() polish machine for cars with variable rotation ![]() ![]() and a bosch grender ![]() first time I use sand paper brush from 60,80,120 to take away the welding ecses ![]() second time I use sand paper brush 120 and after 350 ![]() ![]() and the last I use the wool disk or textil material disk.with polish paste. red or brown is for steinless steel and wite paste for aluminium ![]() ![]()
here I have some picture with polish steps, ![]() this cost 300 sw kr ![]() after 120 sand paper brush ![]() after 350 sand paper brush ![]() after wool disk and paste ![]() ![]() you can see more polishing work when I build the aluminium tork arm in a page 3 of this topic kindly Valy
Re: TOOLS FOR BIKE BUILDERSValy, I would like to see picture on how you attached the quick change chuck to the shaft. I got started on mine yesterday. I knocked out the drilling shaft base, I will post pictures on my progress on monday...
today I start to polish the frame pipes for my new bike ![]() ![]() ![]() ![]() ![]() ![]()
Re: TOOLS FOR BIKE BUILDERSHeres some pictures of the parts i got done last friday and today...
Main cutter Block... ![]() ![]() The back of the main cutter block... ![]() Shaft Guide adapter block ![]() Back of the shaft guide adapter... ![]() Cutter Shaft Guide. I still need to ream this for the bearings... I could have left this as a rectangle but i wanted try some surface milling... ![]() ![]() ![]() This is how i will attach the actual cutter guide block to the adapter, these are threaded holes... ![]() Shaft guide and adapter bolted together... ![]() ![]() ![]() All tree parts together... ![]() ![]() Im still waiting on some parts... but I will update when I get some more parts done...
Re: TOOLS FOR BIKE BUILDERShello hondataeg6 you did a very good job there
you will have sow mutch fun with it Valy
here i have some pictures what you wish ![]() ![]() ![]() ![]() ![]()
Re: TOOLS FOR BIKE BUILDERSThanks for the compliments. i just hope it works just as the original
Re: TOOLS FOR BIKE BUILDERSYou have shown us a very good set of materials you need for your bike. They seem to be very durable especially the steels. Welding will do an important role in the fixing of garage things like this.
My seo
because I dont have a lathe [yet ![]() ![]() ![]() ![]() ![]() ![]() I will use lathe cutters but you can use and others ![]() ![]() ![]() ![]() you can use one or 2 cutters in and out ![]() ![]() ![]() ![]() next days I will show you guys how this cutter works
I promis picture with my build fly cutter hire i cut my drops off ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Who is onlineUsers browsing this forum: No registered users and 3 guests |
